need tip on bypass hose nipple install (slots) #1400147
03/10/13 12:37 PM
03/10/13 12:37 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
im sure there is a tool for this that fits in the slots.i need a homemade one,ideas?
Re: need tip on bypass hose nipple install (slots) [Re: mcmopars] #1400148
03/10/13 12:57 PM
03/10/13 12:57 PM
ideas?
Pliers or vice grips with something around the nipple to protect it from the jaw serrations. It's NPT so dont forget the pipe dope on the threads. EDIT grip it with the pliers away from the outer end & in as close to the threads as you can but they are pretty stout pieces pretty much just a plumbers nipple with a lip to retain the hose & the slots for easy installation on the assembly line. You could cut a piece of metal to fit the slots if desired.
Re: need tip on bypass hose nipple install (slots) [Re: RapidRobert] #1400149
03/10/13 01:03 PM
03/10/13 01:03 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i can do that. but im wanting something to tighten it up via the slots so i dont mar it up
Re: need tip on bypass hose nipple install (slots) [Re: mcmopars] #1400150
03/10/13 02:15 PM
03/10/13 02:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use an old rod adjuster tool.It looks like a huge flat screwdriver that they used on old Jeeps etc.It tightened up the socket around the ball.Fits a ratchet.You can take a piece of steel and grind it so it looks like a big screw driver end.Fit it to the slots and go.Rocky
Chrysler Firepower
Re: need tip on bypass hose nipple install (slots) [Re: therocks] #1400151
03/10/13 02:53 PM
03/10/13 02:53 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i dont have an adjustment tool.looks like ill fab up a piece of stock
Re: need tip on bypass hose nipple install (slots) [Re: mcmopars] #1400152
03/10/13 03:24 PM
03/10/13 03:24 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
They really don't have to be all that tight Just apply some good pipe joint sealer to the threads and some slight pressure with slip joint pliers With a hose hooked to it where is it going to go? I have been a professional technician for over 30 years and the most common mistake I see is people OVER tightening fittings and fasteners.
Good clean threads and the correct sealer
Gus
64 Plymouth Savoy
Dana 60
Re: need tip on bypass hose nipple install (slots) [Re: fourgearsavoy] #1400153
03/10/13 07:08 PM
03/10/13 07:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I had a file thin enough to fit the slots in the nipple, put across the nipple long ways that is. Used that and a pair of pliers to tighten up the fitting enough.
Don't be the exception.
Re: need tip on bypass hose nipple install (slots) [Re: Supercuda] #1400154
03/11/13 01:26 AM
03/11/13 01:26 AM
I would use a small Crescent wrench on the file
Re: need tip on bypass hose nipple install (slots) [Re: mcmopars] #1400155
03/11/13 01:40 AM
03/11/13 01:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I made it, started with a piece of 3/4" hex stock , I made 2 actually because 1970 they went to 2 different size nipples , 1/2" and 5/8" hose. Even though all the cars I own are 69.
I drilled a hole in the middle of each hex piece for a press fit on the appropriate size dowel pins that fit in the nipples and I machined a screwdriver tip onto each one then I pressed in the dowels ...
Re: need tip on bypass hose nipple install (slots) [Re: mcmopars] #1400156
03/11/13 11:54 PM
03/11/13 11:54 PM
cbusters Offline
cbusters  Offline
I started with a six point deep socket and drove a piece of machined flat stock across two of the points inside and knocked it to the bottom of the socket. I think it may have been 5/8 that fit down on both nipples and didn't wobble. It doesn't mark up the fitting either. Picture if you need it.
Re: need tip on bypass hose nipple install (slots) [Re: cbusters] #1400157
03/12/13 01:31 AM
03/12/13 01:31 AM
As double R would say, ding ding ding I do believe we have a winna
Re: need tip on bypass hose nipple install (slots) [Re: cbusters] #1400158
03/12/13 07:08 AM
03/12/13 07:08 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i like this the best.i will be working this weekend on it
Re: need tip on bypass hose nipple install (slots) [Re: RapidRobert] #1400159
03/12/13 09:57 AM
03/12/13 09:57 AM
cbusters Offline
cbusters  Offline
Thank you, thank you! I want to send one out to all my homies, even though "Homie don't play that".
Re: need tip on bypass hose nipple install (slots) [Re: cbusters] #1400160
03/12/13 11:39 AM
03/12/13 11:39 AM
BDW Online content
BDW  Online Content
Need a pic of this awesomeness!
Re: need tip on bypass hose nipple install (slots) [Re: cbusters] #1400161
03/12/13 12:02 PM
03/12/13 12:02 PM
If you send one out to this Homie all will be good in the 'hood
Re: need tip on bypass hose nipple install (slots) [Re: BDW] #1400162
03/12/13 06:59 PM
03/12/13 06:59 PM
cbusters Offline
cbusters  Offline
11/16 6 pt Craftsman deep 3/8 drive, and machine steel, not flat stock. Flat stock is softer.
Re: need tip on bypass hose nipple install (slots) [Re: cbusters] #1400163
03/12/13 07:48 PM
03/12/13 07:48 PM
BDW Online content
BDW  Online Content
You da Man!
