Re: need tip on bypass hose nipple install (slots)
[Re: mcmopars]
#1400148
03/10/13 12:57 PM
03/10/13 12:57 PM
RapidRobert
ideas?
Pliers or vice grips with something around the nipple to protect it from the jaw serrations. It's NPT so dont forget the pipe dope on the threads. EDIT grip it with the pliers away from the outer end & in as close to the threads as you can but they are pretty stout pieces pretty much just a plumbers nipple with a lip to retain the hose & the slots for easy installation on the assembly line. You could cut a piece of metal to fit the slots if desired.
[Re: mcmopars]
#1400150
03/10/13 02:15 PM
03/10/13 02:15 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I use an old rod adjuster tool.It looks like a huge flat screwdriver that they used on old Jeeps etc.It tightened up the socket around the ball.Fits a ratchet.You can take a piece of steel and grind it so it looks like a big screw driver end.Fit it to the slots and go.Rocky
Chrysler Firepower
[Re: therocks]
#1400151
03/10/13 02:53 PM
03/10/13 02:53 PM
Posts: 1,012 indiana
mcmopars
indiana
i dont have an adjustment tool.looks like ill fab up a piece of stock
[Re: mcmopars]
#1400152
03/10/13 03:24 PM
03/10/13 03:24 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
They really don't have to be all that tight Just apply some good pipe joint sealer to the threads and some slight pressure with slip joint pliers With a hose hooked to it where is it going to go? I have been a professional technician for over 30 years and the most common mistake I see is people OVER tightening fittings and fasteners. Good clean threads and the correct sealer Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1400153
03/10/13 07:08 PM
03/10/13 07:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I had a file thin enough to fit the slots in the nipple, put across the nipple long ways that is. Used that and a pair of pliers to tighten up the fitting enough.
[Re: mcmopars]
#1400156
03/11/13 11:54 PM
03/11/13 11:54 PM
Posts: 784 Florida
cbusters
im sure there is a tool for this that fits in the slots.i need a homemade one,ideas?
I started with a six point deep socket and drove a piece of machined flat stock across two of the points inside and knocked it to the bottom of the socket. I think it may have been 5/8 that fit down on both nipples and didn't wobble. It doesn't mark up the fitting either. Picture if you need it.
[Re: cbusters]
#1400158
03/12/13 07:08 AM
03/12/13 07:08 AM
mcmopars
indiana
i like this the best.i will be working this weekend on it
[Re: RapidRobert]
#1400159
03/12/13 09:57 AM
03/12/13 09:57 AM
Posts: 784 Florida
cbusters
As double R would say, ding ding ding I do believe we have a winna
Thank you, thank you! I want to send one out to all my homies, even though "Homie don't play that".
[Re: BDW]
#1400162
03/12/13 06:59 PM
03/12/13 06:59 PM
Posts: 784 Florida
cbusters
Need a pic of this awesomeness!
11/16 6 pt Craftsman deep 3/8 drive, and machine steel, not flat stock. Flat stock is softer.
[Re: cbusters]
#1400163
03/12/13 07:48 PM
03/12/13 07:48 PM
Posts: 4,740 Florida
BDW
