My brothers Ram van will not run. #1398943
03/08/13 01:13 AM
03/08/13 01:13 AM
North Texas
3
360cuda Offline OP
360cuda  Offline OP
North Texas
A couple of weeks ago, my brother was driving his 2001 Ram 1500 van with a 318. It started blowing fuses on the ignition spark circuit. He replaced the fuse several times to get it home. Now it will not run at all. What will cause this? It's getting fuel. Can we bypass the fuse to the coil and make it run? He has replaced the computer, and the crank sensor. It is no longer blowing fuses, but has no spark.
Re: My brothers Ram van will not run. [Re: 360cuda] #1398944
03/08/13 08:38 AM
03/08/13 08:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I replaced a lot of coils on those.I wouldnt hot wire it though.You could have a major melt down.Pull the wires that feed the coil and ign on see if its getting power.Coil might have shorted inside.Rocky
Chrysler Firepower
Re: My brothers Ram van will not run. [Re: therocks] #1398945
03/08/13 12:25 PM
03/08/13 12:25 PM
North Texas
3
360cuda Offline OP
360cuda  Offline OP
North Texas
Sorry... the coil is also new, along with everything else that I mentioned. It is sitting in a shop right now. The mechanic don't have a clue.
Re: My brothers Ram van will not run. [Re: 360cuda] #1398946
03/09/13 01:38 AM
03/09/13 01:38 AM
pennsylvania
poboyengineering Offline
pennsylvania
if i remember correctly, the asd relay powers the fuel pump, injectors and the coil. another lead goes to the fuel pump. if the relay is shorted, it will cause all kinds of trouble like this. just a thought........
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: My brothers Ram van will not run. [Re: poboyengineering] #1398947
03/09/13 02:09 AM
03/09/13 02:09 AM
North Texas
3
360cuda Offline OP
360cuda  Offline OP
North Texas
Thanks, will give it a try.
Re: My brothers Ram van will not run. [Re: poboyengineering] #1398948
03/09/13 11:33 AM
03/09/13 11:33 AM
Ohio
john55 Offline
john55  Offline
Ohio
...and oxygen sensor heaters try unplugging the 02's
The Plymouth Win You Over Beat Goes On
