Original paint ? #1398892
03/07/13 11:16 PM
03/07/13 11:16 PM
KY
b5a12bee Offline OP
b5a12bee  Offline OP
KY
How do you tell if a car still has it's original paint. I know there be some orange peel and not as slick as today's paint, but how do you tell if is an older repaint? Thanks
Re: Original paint ? [Re: b5a12bee] #1398893
03/08/13 01:21 AM
03/08/13 01:21 AM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Look. Exam. Inspect. Study. Every inch. Up under weatherstripping. In door, trunk and hood jams. Along moulding. In wheel-wells and undercarriage. Trim. Glass. Study it all. Find the flaws. Photograph in sun to find mismatch colors and study photographs. Behind bumpers. Look for primer. Analyze every component you can to see if there are paint lines, or evidence of repaint. If you take your time - its hard to miss unless the repaint is done professionally, and redone as a concourse resto.
Re: Original paint ? [Re: WyleECoyote] #1398894
03/08/13 08:22 AM
03/08/13 08:22 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Its pretty easy to tell without much effort once you figure it out. I can usually tell in seconds. Even a car that was completely professionally repainted in the first month and weathers for 4 decades never quite looks the same. I doubt these modern 100% rotisserrie jobs will look quite the same as say my car (original 1970 paint) in 2040... Can you even get that exact paint anymore? not the color, but the actual paint? I'm sure some enviro-nut somewhere has decided it was too evil to use...
Re: Original paint ? [Re: Pale_Roader] #1398895
03/08/13 09:47 AM
03/08/13 09:47 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
If the paint looks perfect with no flaws in any of the seams it is not original. I saw one original paint duster with a hair in the paint (on driver fender) and seen many original paint cars where it looks like they only used a grinder on the lead roof/quarter panel seams. The lower rocker seams are also finished terribly.
Chrysler paint had a good bit of lead in it so I doubt you can buy the exact paint mix today due to the EPA.
Of all the car companies I dont think any had more durable paint than Chrysler. (I believe GM use laquer in the muscle car years and did not hold up well over time)
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Original paint ? [Re: Rapid340] #1398896
03/09/13 12:24 PM
03/09/13 12:24 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Ive had a few original paint cars. Both had runs, sags and spot with little coverage.
Re: Original paint ? [Re: AdamR] #1398897
03/11/13 10:40 PM
03/11/13 10:40 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Yeah---Tell me about it---A good example below
Re: Original paint ? [Re: Michael] #1398898
03/11/13 11:06 PM
03/11/13 11:06 PM
Central Louisiana
jim Offline
jim  Offline
Central Louisiana
Michael, what color is that?
Re: Original paint ? [Re: jim] #1398899
03/12/13 09:11 AM
03/12/13 09:11 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Heres a under hood shot of my 73 Duster, Original paint. The passenger side has very little paint on the fire and bottom of the hood.
Re: Original paint ? [Re: jim] #1398900
03/12/13 09:28 PM
03/12/13 09:28 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Beige
