Re: 66 fury 3 rear end
[Re: dodgedartgt]
#1398350
03/07/13 04:15 AM
03/07/13 04:15 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
Almost without a doubt, when new it had an 8-3/4" rear axle, probably a "741" case. Yes, gear sets are available. Crawl under the passenger side of the car and look for the seven digit casting number on the nose of the carrier. Hope it helps, Mike in FL
The last three digits are what tells you which case it has. If it is stock it will have either the 741 or the 742 in it. If not stock it could have the later not so desireable 489 cae in it, check it carefully to make sure which one it is before going forward
[Re: dodgedartgt]
#1398351
03/07/13 06:01 AM
03/07/13 06:01 AM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
Yo Mike ..... drivers side
[Re: Cab_Burge]
#1398357
03/08/13 10:30 AM
03/08/13 10:30 AM
Posts: 15,487 Florida
scratchnfotraction
awesome thanks guys i will crawl under her this weekend and see what i can find out..next question where would i find gears for her? i havent come up with anything in my searches
Dr Diff
X2 Dr Diff has everything you need + some extras
[Re: tbland09]
#1398359
03/08/13 10:34 AM
03/08/13 10:34 AM
BeEtLeJuIcE !
Florida STAYcation
Is there a tag on one of the studs ?
