66 fury 3 rear end #1398348
03/07/13 12:13 AM
03/07/13 12:13 AM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
i have a 66 4 fury 3 4 door with the 318 poly in it i have been searching and searching to find out what rear end it has and if i can get lower gears for it or if i would have to find a different rear end all together?????
Re: 66 fury 3 rear end [Re: tbland09] #1398349
03/07/13 12:19 AM
03/07/13 12:19 AM
SW FL
dodgedartgt Offline
dodgedartgt  Offline
SW FL
Almost without a doubt, when new it had an 8-3/4" rear axle, probably a "741" case. Yes, gear sets are available.
Crawl under the passenger side of the car and look for the seven digit casting number on the nose of the carrier.
Hope it helps,
Mike in FL
Re: 66 fury 3 rear end [Re: dodgedartgt] #1398350
03/07/13 04:15 AM
03/07/13 04:15 AM
Hope it helps,
Mike in FL
The last three digits are what tells you which case it has. If it is stock it will have either the 741 or the 742 in it. If not stock it could have the later not so desireable 489 cae in it, check it carefully to make sure which one it is before going forward
Re: 66 fury 3 rear end [Re: dodgedartgt] #1398351
03/07/13 06:01 AM
03/07/13 06:01 AM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
Hope it helps,
Mike in FL
Yo Mike ..... drivers side
Re: 66 fury 3 rear end [Re: BeEtLeJuIcE !] #1398352
03/07/13 11:33 AM
03/07/13 11:33 AM
that's my buddy Mikey & I think the Florida sun has cooked his brain a bit
Re: 66 fury 3 rear end [Re: dodgedartgt] #1398353
03/07/13 06:35 PM
03/07/13 06:35 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Except I'll go 100% for when it was new. C-bodies had 8 3/4 exclusively until 1971 I believe, then the 8 1/4" started filtering in on the smallblock cars.
Re: 66 fury 3 rear end [Re: Fury Fan] #1398354
03/07/13 06:38 PM
03/07/13 06:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
match it to the pictures from the tech archives. http://www.moparts.org/Tech/Archive/axle/6.html
Re: 66 fury 3 rear end [Re: stumpy] #1398355
03/07/13 11:47 PM
03/07/13 11:47 PM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
awesome thanks guys i will crawl under her this weekend and see what i can find out..next question where would i find gears for her? i havent come up with anything in my searches
Re: 66 fury 3 rear end [Re: tbland09] #1398356
03/08/13 01:39 AM
03/08/13 01:39 AM
Dr Diff
Re: 66 fury 3 rear end [Re: Cab_Burge] #1398357
03/08/13 10:30 AM
03/08/13 10:30 AM
scratchnfotraction Offline
Dr Diff
X2 Dr Diff has everything you need + some extras
Re: 66 fury 3 rear end [Re: tbland09] #1398358
03/08/13 10:33 AM
03/08/13 10:33 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
http://www.google.com/#hl=en&sclient...bvm=bv.43287494,d.d2k&fp=839ff51634e23e13&biw=1102&bih=451
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 66 fury 3 rear end [Re: tbland09] #1398359
03/08/13 10:34 AM
03/08/13 10:34 AM
Florida STAYcation
Florida STAYcation
Is there a tag on one of the studs ?
