Dual Quad Air Cleaner Assembly Ever Made For 440? #1398011
03/06/13 01:08 PM
03/06/13 01:08 PM
Newburgh, NY
Old_Moparz Offline OP
Newburgh, NY
(edit....For a stock appearance)
Making a base plate is probably what I'll end up doing, but I was wondering if Chrysler or another company ever made an air cleaner base & lid for a dual quad set up? I have an aluminum Offenhauser intake for the 440 I want to use, but would like to have just one larger air cleaner base & lid instead of two smaller ones. I always liked the chrome Hemi one & thought I'd like to duplicate that somehow.
Does anyone remember if something like this existed, even back in the late 60's or 70's?
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Old_Moparz] #1398012
03/06/13 02:56 PM
03/06/13 02:56 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The difficulty is going to be on the distance between the two carbs. Even the Street Hemi and 413 inline manifolds had different spacing. If you get lucky and the spacing is that same on your manifold and the hemi you'll be good to go OR you could get the hemi air cleaner and modify the base by moving one opening.
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Jim_Lusk] #1398013
03/06/13 04:08 PM
03/06/13 04:08 PM
Batavia,Ohio,
Moparmick Offline
Moparmick  Offline
Batavia,Ohio,
1962 383 RB had dual quads from factory, dont remember what type air cleaner they had might be worth a look
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Moparmick] #1398014
03/06/13 04:12 PM
03/06/13 04:12 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I believe two small air cleaners
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: GTX MATT] #1398015
03/06/13 04:18 PM
03/06/13 04:18 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: thehemikid] #1398016
03/06/13 05:36 PM
03/06/13 05:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
No factory dual quad 440s, there s a member (Steve paint it black?) that makes custom fiberglass baseplates similar to the '69-'71 oval fresh air-air clewaners. web page - Hybrid Fiberglass Solutions.
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: GTX MATT] #1398017
03/06/13 06:08 PM
03/06/13 06:08 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And very expensive if you can find them !
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: 62maxwgn] #1398018
03/06/13 06:17 PM
03/06/13 06:17 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
You meaaaaaaaaaaaaan...something like this?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Pyper70] #1398019
03/06/13 06:20 PM
03/06/13 06:20 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I bought mine off Steve (PaintItBlack) as already mentioned...the problem was the spacing...Nothing too troublesome. I cut out the center openings and reset them to where I needed to be in the engine bay between my wiper motor and my MSD ignition...Little 'glass work and it looks fantastic...Before and after shots below
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Pyper70] #1398020
03/06/13 06:29 PM
03/06/13 06:29 PM
Newburgh, NY
Newburgh, NY
Thanks for the replies.
Looks like it's what I had thought, nothing available except for the older, expensive ones that probably won't fit anyway.
That's pretty cool & looks like what I'll be leaning towards so I'll have to contact him, thanks. And I just bookmarked his page, too.
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: 62maxwgn] #1398021
03/07/13 10:28 AM
03/07/13 10:28 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Yep, pricey. No worse than air grabber parts, though.
Those are teh same air cleaners used on some years of 300s and also 57-58 Fury. There was a guy reproducing them but when I bought my set in '07-08 he was getting near the end of his stockpile.
The baseplates for these fit the 4 1/2" AFBs (the old OEM ones) and don't fit any 68-newer or the Eddy carbs. The short filters used with them are not available but I've found a brand-X one that can be formed into shape. Either way, the filter is only about 2" tall. They breathe thru about a 3/16" gap around the bottom edge of hte air cleaner. ()
Edit - added a crappy photo that shows the baseplate. That's the top of hte baseplate, what you'd see when taking the lid off. It's wierd compared to 'normal' air cleaners.
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Fury Fan] #1398022
03/07/13 03:56 PM
03/07/13 03:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
There's a few air filters left !
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: 62maxwgn] #1398023
03/07/13 04:35 PM
03/07/13 04:35 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Only 4? Hope you're not driving it much!
The boxes mine came in are far more modern.
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Fury Fan] #1398024
03/07/13 04:45 PM
03/07/13 04:45 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Doubt I'll ever use them.
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Pyper70] #1398025
03/07/13 06:55 PM
03/07/13 06:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pete did you transfer those measurement to steve so he can make one that fits ?
Did that start life as a hemi replacement or was it for the stage5 hemi intake ? What lid did you use ? And what the standoffs on the carbs ?
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: JohnRR] #1398026
03/08/13 05:03 AM
03/08/13 05:03 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Started off life as a Stage V as it sat in the white. I removed both openings with a Dremel and a carbide saw blade. Relocated them to where the air cleaner could sit comfortably in front of my 3spd wiper motor (about 3/4") and slightly inside of my MSD distributor because it was so tall (about 1/2") Centered it on the carb's but I also needed it to drop down a little further because I have insulation on the inside of my hood.
I used the Stage V lid as well. It was going to be hard to relocate those bevels so the easier thing to do was dog-leg the mounting studs on the carb's and weld them on like that. Put a nut on the bottom section to jamb it up against stud opening.
When you say the standoff's on the carbs..what do you mean? I gave Steve all my measurements so he can have them on hand so he can create a more professional looking model. You can't see any of my work once the filter and lid are on. It didn't take long to make it, from when I received the assembly, to mapping out the correct position, cutting, duct taping it into place and then laying down the 'glass over the voids.....3 weeks...not bad for someone who doesn't work with it on a daily basis.
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Pyper70] #1398027
03/08/13 03:58 PM
03/08/13 03:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
In a couple of pictures it looks like you have some spacer rings on the carbs ? where those just for your mock up purposes ?
What is the stud to stud spacing between the 2 carbs ? I'd like to compare it to a stock Hemi intake , I have both a stock Hemi and Stage V .
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: JohnRR] #1398028
03/08/13 05:39 PM
03/08/13 05:39 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
The spacers came with the Route 66 K&N tear drop assembly I had originally purchased and while I do love that look, My hood clearances wont allow for me to install them without a cowl hood induction (its on my mind and in the works) For now I sent out one of those 2" collars and had them milled in 1/4" intervals and placed 2 on each carb so as to allow clearance for the linkages on my edelbrocks.
The distance center to center on my carbs is 6 7/16". The distance from the front of the air cleaner to the center stud on the front carb is 7 3/4", and the distance from the rear of the air cleaner to the stud of the rear carb 7 3/8".
Hope the numbers help you out
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Pyper70] #1398029
03/08/13 10:28 PM
03/08/13 10:28 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
This is an Edelbrock.
Re: Dual Quad Air Cleaner Assembly Ever Made For 440? [Re: Cudajon] #1398030
03/09/13 07:32 AM
03/09/13 07:32 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Awe, those carters look so cute! Just joshin, looks like a pretty clean setup once you cover up that wiring some. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
