Pictures of the trunk trim piece installed? #1398009
03/06/13 12:49 PM
03/06/13 12:49 PM
Leesburg, VA
V
VA_Mopars Offline OP
V
Leesburg, VA
I am installing the trim on my 69 Charger and noticed a problem. The piece that goes across the top of the tail panel above the lights is mounted with 7 screws. Were they all the same size from the factory or did they use two different sizes?
I pulled off two different sizes when removing the piece but don't know if they were original or not and don't know which location used the smaller ones if appropriate. Pictures would be great, if anyone has any.
Thanks,
Joe
Re: Pictures of the trunk trim piece installed? [Re: VA_Mopars] #1398010
03/06/13 08:56 PM
03/06/13 08:56 PM
Leesburg, VA
V
V
Leesburg, VA
Bump for the evening viewers...
