I am installing the trim on my 69 Charger and noticed a problem. The piece that goes across the top of the tail panel above the lights is mounted with 7 screws. Were they all the same size from the factory or did they use two different sizes?
I pulled off two different sizes when removing the piece but don't know if they were original or not and don't know which location used the smaller ones if appropriate. Pictures would be great, if anyone has any.
Thanks,
Joe
