Is this water neck OK? #1397524
03/05/13 02:44 AM
03/05/13 02:44 AM
Vancouver, BC, Canada
rtriv Offline OP
rtriv  Offline OP
I just noticed that my water neck seems quite short and lacks the bulge around the top edge? (Yes, after assembling and painting the engine of course)Is this correct or has it been cut? It certainly doesn't look like it has been but every other one I've ever seen has a bulge around the top edge to prevent the hose from coming off.... Engine is a 67 383. See attached pic.
Re: Is this water neck OK? [Re: rtriv] #1397525
03/05/13 02:47 AM
03/05/13 02:47 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Change it.. Sorry..
Re: Is this water neck OK? [Re: 1_WILD_RT] #1397526
03/05/13 03:06 AM
03/05/13 03:06 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Change it.. Sorry..
Re: Is this water neck OK? [Re: Jim_Lusk] #1397527
03/05/13 09:14 AM
03/05/13 09:14 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i wouldnt trust it.
Re: Is this water neck OK? [Re: rtriv] #1397528
03/05/13 12:03 PM
03/05/13 12:03 PM
get an iron one (with the lip) & paint it seperately & you're good. Yes it does make you wonder how/why the lip dissappeared off of that one because they all have them
Re: Is this water neck OK? [Re: RapidRobert] #1397529
03/05/13 12:36 PM
03/05/13 12:36 PM
P
Paul_Fancsali Offline
P
Use some Indian head shellac as sealant and forget it once that crap sets up its like iron
Re: Is this water neck OK? [Re: rtriv] #1397530
03/05/13 04:21 PM
03/05/13 04:21 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Get a replacement from Napa...
Part # BK 6051051, $5.95
Just my $0.02...
Re: Is this water neck OK? [Re: Sinitro] #1397531
03/05/13 04:32 PM
03/05/13 04:32 PM
Heat, Pressure, Slip, GOOOOOOOOOOSH, que the cussing!
Re: Is this water neck OK? [Re: rtriv] #1397532
03/05/13 05:47 PM
03/05/13 05:47 PM
Fort Collins, CO
justintyme Offline
justintyme  Offline
Fort Collins, CO
The small cost and effort to replace it is nothing compared to the mess and cost of having your hose blow off leaving you stranded.
Re: Is this water neck OK? [Re: justintyme] #1397533
03/05/13 06:17 PM
03/05/13 06:17 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
Or.....you can try this one.. go to: www.TerrysAutoLab.com
Plymouth Makes It!
Re: Is this water neck OK? [Re: rtriv] #1397534
03/05/13 06:38 PM
03/05/13 06:38 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Whatever you do, DO NOT replace it with a chrome one. It WILL leak! You have been warned...
Re: Is this water neck OK? [Re: rtriv] #1397535
03/05/13 06:55 PM
03/05/13 06:55 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
I remember buying a new one from the auto parts store that looked just like that one many years ago and questioning it as well .
Really thick base and no sealing bead on the hose end , KEM brand i think it was.
Re: Is this water neck OK? [Re: 318 Stroker] #1397536
03/05/13 08:12 PM
03/05/13 08:12 PM
Ive taken the chrome jokers and sanded them on a belt sander, then taped the rest of the shiney off, and bead blasted it because the customer is always right, and I hate leaks. It worked!!
Re: Is this water neck OK? #1397537
03/06/13 03:18 AM
03/06/13 03:18 AM
rtriv Offline OP
rtriv  Offline OP
I thought it would probably go this way. I was hoping somebody would come back and say "oh it's fine they're all like that"! Does anybody else have any experience with the NAPA one? Is it cast aluminum? Seems like the chrome one is definitely out based on the comments above and some other posts I found on the subject. Does anybody repop a cast iron version?
Re: Is this water neck OK? [Re: rtriv] #1397538
03/06/13 07:36 AM
03/06/13 07:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a chrome on my 440.Been on 10 years and no leaks.I used the gasket and a bit of brown Permatex.Probally have a few stock ones in my other garage.Rocky
Chrysler Firepower
Re: Is this water neck OK? [Re: rtriv] #1397539
03/06/13 03:58 PM
03/06/13 03:58 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The Napa is a cast iron repop, looks/works fine.
The chrome jobber is junk, made of recycled Coors beer cans..
One can sand it, mill it and use super sealer and it will still leak, something to do with the casting when hot changes shape..
Just my $0.02..
Re: Is this water neck OK? [Re: Sinitro] #1397540
03/06/13 08:09 PM
03/06/13 08:09 PM
So.IL.Home of Popeye
P
plum340demon Offline
P
I bought a iron one from napa once that did not have a lip on top.I put the indian head sealer on the hose.It blew off with my head under the hood.Learned the hard way.
Re: Is this water neck OK? [Re: plum340demon] #1397541
03/07/13 02:56 AM
03/07/13 02:56 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
See the pix, it does have a gripping lip on it..
We bought and installed 4 or 5 without any issues..
Just my $0.02..
Re: Is this water neck OK? [Re: RoadRunnerLuva] #1397542
03/07/13 03:52 AM
03/07/13 03:52 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
thanks for posting this...i just bought one...looks really awsome!
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Is this water neck OK? [Re: sublimehemi] #1397543
03/08/13 05:58 PM
03/08/13 05:58 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Would you update this post when you get yours?? I agree it looks super trick.. Of course for $100 it better....
