BF Goodrich 295/50 15 Tire Measurement Please #1397494
03/05/13 12:24 AM
03/05/13 12:24 AM
Out in Left Field, NY
bobs66440 Offline OP
I'm trying to see if a BFG 295/50 15 on a 10" wide wheel (5" backspace) will fit on the rear of my Charger. I have all the measurements I need and I think it will be ok, but I would just like to know what the exact width of this tire mounted on a 10" wide wheel is so I can be absolutely sure.
Thanks!
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: bobs66440] #1397495
03/05/13 09:26 AM
03/05/13 09:26 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
PM me if you don't get an answer. work overnights and I'm heading to bed, but can check when I wake up if you remind me.
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: 68KillerBee] #1397496
03/05/13 10:03 AM
03/05/13 10:03 AM
Ok, thanks!
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: bobs66440] #1397497
03/05/13 10:08 AM
03/05/13 10:08 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Unless the Charger and Coronet have different wheelhouse dimentions, I don't think it will fit. I installed 275 60 15s on my 66 Coronet with 5-1/4" Backspacing (special order) from wheel vintiques. I have 3/8" from case to spring on the inside and 3/8" from case to outer quarter. My rear wheels are 8".
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: bobs66440] #1397498
03/05/13 10:11 AM
03/05/13 10:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm going to guess that tire will NOT fit under your Charger. a 275/60/15 will barely fit. and that's on an 8" rim. You don't have enough room for a 10" rim and a 12" tire back there. I've had 3 67's (2 coronets and 1 GTX) the biggest tire I ran was a 275/60/15 and that even scrubs a little from time to time. 68-up b-body no problem.
Coming soon!!!!
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: bobs66440] #1397499
03/05/13 10:17 AM
03/05/13 10:17 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Before I ordered my Wheels and Nitto 555R 275 60 15 redlines, I tried on a set of M&H 275 60 15 on 7" steelies that my budy had. Here is a photo of how close they are.
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: Hemi ragtop] #1397500
03/05/13 10:48 AM
03/05/13 10:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
275's
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: Mr.Yuck] #1397501
03/05/13 11:09 AM
03/05/13 11:09 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
295/650/15 dunlop G/T quailifiers on 10" wide centerlines wit 5" back spacing.
it helps to have a rear sway bar and stiff shocks to keep things in place around corners because it,s a tight fit.
Coronet of the same years outer wheel openings are NOT the same as the chargers
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: ChinooK440] #1397502
03/05/13 11:25 AM
03/05/13 11:25 AM
Yes, thanks. I'm sure they will fit if I get the backspacing correct. Both of these Chargers also have 295s on 10" wheels with 5" backspacing, so your info helps to confirm. I just wanted to get a width measurement of the BFG TA Radials because these are what I will be using and as you say, it will be tight and I want to cover all my bases. I know that the same size tire of different manufacture will vary slightly.
Do yours rub at all?
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: bobs66440] #1397503
03/05/13 11:31 AM
03/05/13 11:31 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
I hear ya Bob i just wanted to clarify for the people showing pictures of coronet wheel wells
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: ChinooK440] #1397504
03/05/13 11:34 AM
03/05/13 11:34 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It's not the wheel lip, it's up higher in the 1/4 where that mid body line is.... go for it if you think it will fit.
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: ChinooK440] #1397505
03/05/13 12:09 PM
03/05/13 12:09 PM
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: bobs66440] #1397506
03/05/13 01:08 PM
03/05/13 01:08 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
No they didn,t rub at all.
I understand your concern though as sizes advertised as the same size can sometimes vary on different makes of tires .
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: ChinooK440] #1397507
03/05/13 01:11 PM
03/05/13 01:11 PM
Thank you!
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: bobs66440] #1397508
03/08/13 05:47 PM
03/08/13 05:47 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Well I went out to cruise and just remembered this post. I'd say at the widest spot its 12 1/4-1/4 inches wide. Mine rubs occasionally around tight corners/ up hills turning, but I try to avoid that. Also added a really small spacer and that seemed to get rid of it a lot.
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: 68KillerBee] #1397509
03/08/13 09:48 PM
03/08/13 09:48 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
OT IMO, if there was a Hall of fame for tires, 295/50/15 would be voted in in the first round.
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: 68KillerBee] #1397510
03/09/13 12:15 AM
03/09/13 12:15 AM
I appreciate it! Thank you. That helps!
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: bobs66440] #1397511
03/09/13 01:58 AM
03/09/13 01:58 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I had N50 15's on a 10" rim don't remember the backspace on my 67 Charger.
I have 275/50/15's on a 10" rim with 6" backspace on my 71 Demon.
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: demon440] #1397512
03/09/13 02:39 AM
03/09/13 02:39 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
From BFG's web site the 295/50/15 measures 12.2" on 9.5" rim.
I don't know if that helps you, the 9.5" rim may be close enough to the 10" to get you your measurement.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: BF Goodrich 295/50 15 Tire Measurement Please [Re: hp383] #1397513
03/11/13 09:27 AM
03/11/13 09:27 AM
Thanks!
