73 to 76 A-Body Draglink Question #1397277
03/04/13 02:09 PM
03/04/13 02:09 PM
San Diego
formula S Offline OP
San Diego
Was there any difference between six cylinder and V8 draglinks
Re: 73 to 76 A-Body Draglink Question [Re: formula S] #1397278
03/04/13 02:22 PM
03/04/13 02:22 PM
no difference
Re: 73 to 76 A-Body Draglink Question [Re: RapidRobert] #1397279
03/04/13 02:36 PM
03/04/13 02:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
no difference
Re: 73 to 76 A-Body Draglink Question [Re: autoxcuda] #1397280
03/04/13 03:11 PM
03/04/13 03:11 PM
San Diego
San Diego
Logic tells me that there's no difference, but someone told me that V8's had more drop for pan clearance
Re: 73 to 76 A-Body Draglink Question [Re: formula S] #1397281
03/04/13 03:13 PM
03/04/13 03:13 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
"Someone" doesn't know what they are talking about...
Re: 73 to 76 A-Body Draglink Question [Re: formula S] #1397282
03/04/13 05:03 PM
03/04/13 05:03 PM
On the 64-66 A link yes the V8 one has a dramatic amount of drop compared to the 64-66 A /6 link & is required on a V8 swap on those years (63-66). Someone mentioned once that using the 73 up link rather than the 68-72 link & related components on a 68-76 A body gives a slight amount of addit'l pan clearance for a V8 swap as it positions the center link slightly lower tho as said in either of those 2 categories (68-72) (73-76) the /6 and V8 bars are the same in each category but are different from the other years' group. Something about the idler/pitman arms entering from the other side of the centerlink on the 73 up setup giving a slight bit of addit'l clearance than the 68-72 setup would which might be beneficial/needed on a tight setup & they do interchange & I believe just need the correct pitman/idler & the end holes for the tie rod ends are turned 90 deg between the 2 groups. Not sure if the reported addit'l clearance is correct & may not even be needed & no actual experience with that but just a FYI. I swapped a BB into a /6 shallow centerlink 1969 A body with the engine swap mounts (Schumaker iirc) & the std pan cleared with ease
Re: 73 to 76 A-Body Draglink Question [Re: RapidRobert] #1397283
03/04/13 07:19 PM
03/04/13 07:19 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
Re: 73 to 76 A-Body Draglink Question [Re: SIKPUP] #1397284
03/04/13 07:29 PM
03/04/13 07:29 PM
Oh OK the 68-72 setup rather than the 73-76 is the one that gives the most clearance
Re: 73 to 76 A-Body Draglink Question [Re: RapidRobert] #1397285
03/04/13 07:44 PM
03/04/13 07:44 PM
RobX4406 Offline
RobX4406  Offline
How do you arrive at that, because of the drop in the link.
The attachment method tend to put the area of potential interference in about the same position on both centerlinks.
Since one comes from under, the other from above.
