one last time about 8 3/4 rear for fat tires
#139708
10/21/08 07:22 PM
10/21/08 07:22 PM
Posts: 8,857 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i want to put a 10 wide wheel and and at least a 295 50 15 possibly a 325 50 15 under our challenger i was under the impression that if i used a 66-67 b body rear and offset hangers i could do this i have found a 66 8 3/4 rear but have also see a digram that list all mopar cars(mid 60-70s) rear end measurments acording to it there is no differance at all from a 66-67 b body rear then a 68-70 b body also thought the overall width was same but the perches were closer togeather???? so one final time can i put this rearend under car with that wheel/tire i do not want to have to cut and reweld the spring perches thanks
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: one last time about 8 3/4 rear for fat tires
[Re: Darryls-Demon]
#139713
10/22/08 01:58 AM
10/22/08 01:58 AM
Posts: 463 IN
polaraholic
IN
Your Challenger will look like this with 325/50/15s.
Darryl that is a great shot. I'd like to see more pics of the car. Did you have any problems with the exhaust system?
[Re: DoctorDiff]
#139714
10/22/08 07:08 AM
10/22/08 07:08 AM
This combination usually works best:
1. '65-'67 B-body rearend 2. 10" wheels with 5" of backspacing 3. DoctorDiff 1" offset spring hanger/shackle kit
You do not have to move the spring perches
shoot, i just bought a 69 b body rear which I see is slightly wider than the earlier rear.
If i get this offset hanger kit and 10" wheels, will the 325's fit my 70 cuda? or is there a different offset or backspacing required?
#139715
10/22/08 08:55 AM
10/22/08 08:55 AM
Posts: 8,149 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
[Re: Darryls-Demon]
#139719
10/22/08 11:25 PM
10/22/08 11:25 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
I used the same with the Dr Diff kit and a 67 B body 8 3/4. Worked great. ![](/ubbthreads/images/graemlins/thumbs.gif) I had to move my fuel line is a bit because the spring rubbed on it a slightly.
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#139720
10/22/08 11:26 PM
10/22/08 11:26 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
The car has 275 on the rear
[Re: polaraholic]
#139722
12/02/08 12:19 PM
12/02/08 12:19 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
is a 68-69 b body rear housing wider then one from a 67 b body or is it the spring perches in differnt spots
