one last time about 8 3/4 rear for fat tires #139708
10/21/08 07:22 PM
10/21/08 07:22 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
i want to put a 10 wide wheel and and at least a 295 50 15 possibly a 325 50 15 under our challenger
i was under the impression that if i used a 66-67 b body rear and offset hangers i could do this
i have found a 66 8 3/4 rear but have also see a digram that list all mopar cars(mid 60-70s) rear end measurments
acording to it there is no differance at all from a 66-67 b body rear then a 68-70 b body
also thought the overall width was same but the perches were closer togeather????
so one final time
can i put this rearend under car with that wheel/tire i do not want to have to cut and reweld the spring perches
thanks
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: one last time about 8 3/4 rear for fat tires [Re: toplescuda] #139709
10/21/08 07:32 PM
10/21/08 07:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: one last time about 8 3/4 rear for fat tires [Re: toplescuda] #139710
10/21/08 11:25 PM
10/21/08 11:25 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
This combination usually works best:
1. '65-'67 B-body rearend
2. 10" wheels with 5" of backspacing
3. DoctorDiff 1" offset spring hanger/shackle kit
You do not have to move the spring perches
Re: one last time about 8 3/4 rear for fat tires [Re: toplescuda] #139711
10/22/08 12:00 AM
10/22/08 12:00 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
Your Challenger will look like this with 325/50/15s.
Re: one last time about 8 3/4 rear for fat tires [Re: DoctorDiff] #139712
10/22/08 01:52 AM
10/22/08 01:52 AM
IN
polaraholic Offline
polaraholic  Offline
IN
Doc I thought it was the 68-69 b-body that swapped in without moving the perches and using your offset hangers. Or will they all b-body work that way. I bought a 69 8 3/4 to put in my challenger because of a previous post on this. Is it the size of the rims that makes the 65-67 better?
Re: one last time about 8 3/4 rear for fat tires [Re: Darryls-Demon] #139713
10/22/08 01:58 AM
10/22/08 01:58 AM
IN
polaraholic Offline
polaraholic  Offline
IN
Darryl that is a great shot. I'd like to see more pics of the car. Did you have any problems with the exhaust system?
Re: one last time about 8 3/4 rear for fat tires [Re: DoctorDiff] #139714
10/22/08 07:08 AM
10/22/08 07:08 AM
shoot, i just bought a 69 b body rear which I see is slightly wider than the earlier rear.
If i get this offset hanger kit and 10" wheels, will the 325's fit my 70 cuda? or is there a different offset or backspacing required?
Re: one last time about 8 3/4 rear for fat tires #139715
10/22/08 08:55 AM
10/22/08 08:55 AM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
Re: one last time about 8 3/4 rear for fat tires #139716
10/22/08 10:26 AM
10/22/08 10:26 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The slightly wider '68-'70 B-body rearends also bolt in, but the optimal backspacing on a 10" wheel is around 5.25".
Most off-the-shelf wheels are available in 5" or 5 1/2" backspacing.
Re: one last time about 8 3/4 rear for fat tires [Re: Darryls-Demon] #139717
10/22/08 11:21 PM
10/22/08 11:21 PM
Glendale Az
Glendale Az
The exhaust system is from TTI, including the headers. The exhaust is 3 inch,the only trouble i had is i needed to have a longer rubber brake line made.
Re: one last time about 8 3/4 rear for fat tires [Re: Darryls-Demon] #139718
10/22/08 11:21 PM
10/22/08 11:21 PM
Glendale Az
Glendale Az
another
Re: one last time about 8 3/4 rear for fat tires [Re: Darryls-Demon] #139719
10/22/08 11:25 PM
10/22/08 11:25 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I used the same with the Dr Diff kit and a 67 B body 8 3/4. Worked great. I had to move my fuel line is a bit because the spring rubbed on it a slightly.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: one last time about 8 3/4 rear for fat tires [Re: Kam*Kuda] #139720
10/22/08 11:26 PM
10/22/08 11:26 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
The car has 275 on the rear
1654.5 Mustang
1955 Land Rover
Re: one last time about 8 3/4 rear for fat tires [Re: Kam*Kuda] #139721
10/23/08 12:10 AM
10/23/08 12:10 AM
IN
polaraholic Offline
polaraholic  Offline
IN
Thanks, Both of those cars are awsome. I'm not going to use 10" rims so I think the 69 unit I have will work for me.
Re: one last time about 8 3/4 rear for fat tires [Re: polaraholic] #139722
12/02/08 12:19 PM
12/02/08 12:19 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
is a 68-69 b body rear housing wider then one from a 67 b body or is it the spring perches in differnt spots
1971 charger
