Re: Rear Lower Shock Mount?
[Re: whomper1]
#1397218
03/06/13 02:12 AM
03/06/13 02:12 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
the shock is held on with a nut and flat washer
Actually it's a conical washer. As of about two years ago, they were still available from dealer parts counters (washer outer rear shock bushing, 1319554; washer inner rear shock bushing, 1319555). These are bare steel, same as the U bolts, nuts, spring plate, and spring hangers.
