Rear Lower Shock Mount? #1397214
03/04/13 11:32 AM
03/04/13 11:32 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What the correct hardware configuration for the rear shock plate? Do they use a washer or lock washer? Or is it just a nut against the plate? Are they flanged nuts?
I'm talking about the non-isolator type on an 8 3/4 rearend.
Re: Rear Lower Shock Mount? [Re: mopowers] #1397215
03/05/13 12:00 PM
03/05/13 12:00 PM
Central,AR
hemi_tyme Offline
hemi_tyme  Offline
Central,AR
Lock nut only
Re: Rear Lower Shock Mount? [Re: hemi_tyme] #1397216
03/05/13 03:06 PM
03/05/13 03:06 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
self locking, deep, nut mopar #6023019 against the plate.
Re: Rear Lower Shock Mount? [Re: mopowers] #1397217
03/05/13 03:50 PM
03/05/13 03:50 PM
usa
W
whomper1 Offline
whomper1  Offline
W
usa
the shock is held on with a nut and flat washer
the plate is held against the leaf spring with a locking nut
Re: Rear Lower Shock Mount? [Re: whomper1] #1397218
03/06/13 02:12 AM
03/06/13 02:12 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Actually it's a conical washer. As of about two years ago, they were still available from dealer parts counters (washer outer rear shock bushing, 1319554; washer inner rear shock bushing, 1319555). These are bare steel, same as the U bolts, nuts, spring plate, and spring hangers.
