Lickity Splits journey to Auto-Rama
#1397039
03/04/13 01:10 AM
03/04/13 01:10 AM
Posts: 9,841 MI, usa
dvw
MI, usa
Detroit Auto-Rama is next week. I figured I'd show the Belvedere One time before we beat it up. Of coarse living in Mi means snow and ice. My faithful 95 Cummins fired right up, good. It is a 2WD dually stick which means it gets stuck in frozzen spit,bad. Got my buddy's 4WD Cummins to pull me out,good. Tried to pull my 32'tri axle out of the 3" of ice,bad. I chopped out the ice, still stuck. We strapped both the trucks together along with the trailer out it came. Took it for a drive ,all good. End Saturday,day 1. Sunday a warm front must be at least 30. Next business to pull my supercharged Volare out of the trailer. Charge the battery, air up the slicks, crank it up, won't start. It always starts, except this time. Probably do to the fact that the upper blower pulley came loose during it's last trip to Norwalk. The rotors aren't rotating during crank with out the belt. Pour some fuel in the carbs, fire it up, quits. Another 15 minutes of start a quit finally runs long enough to make it to the shop. Did I mention the tool box drawers were open on the road trip so the tool box tipped and emptied its drawers. End day 2. Hopefully my 1/4 trim panels will be finished tomorrow so I can install them before move in day on Wednesday. Doug
Re: Lickity Splits journey to Auto-Rama
[Re: dvw]
#1397040
03/04/13 11:26 AM
03/04/13 11:26 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Wow sounds like a ordeal for sure.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: dvw]
#1397044
03/04/13 09:06 PM
03/04/13 09:06 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
You're a better man than me!! If I had all that trouble/bad luck, there is NO way I would put that beautiful car in a trailer and tow it anywhere right now. I could only imagine what it would look like after the tool box fell into it, or it came loose from tie-downs, etc!! I would have to wait for the moon to change or something. Hope all goes well.
If you like drag racing, support your local track.
[Re: dvw]
#1397046
03/04/13 09:48 PM
03/04/13 09:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Good luck with it Doug... hope you get best of class... I will see if I can make it down there to check it out... still on the road but we SHOULD be home tomorrow
[Re: racerx]
#1397057
03/06/13 10:03 AM
03/06/13 10:03 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
doug when you get checked in see what class they have you in. You should be able to get into super stock becuase the car can fit into (appear)ss/da. If you put into nostalgia you have some tough comp. Just a thought. Good Luck see you thursday.Jake
JAKES AUTOMOTIVE
[Re: JAKE68]
#1397058
03/06/13 09:32 PM
03/06/13 09:32 PM
Posts: 1,162 s e mich
ro23car
s e mich
it wont be that tough i wont be there cuz i have to work .
