frame connectors on hemi car ? #1396804
03/03/13 07:43 PM
03/03/13 07:43 PM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
Im building a 65 belv. a990 super stock clone. It will just be street driven. Should I put frame connectors on it ? or not ?
Re: frame connectors on hemi car ? [Re: johnzgarage] #1396805
03/03/13 08:16 PM
03/03/13 08:16 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Yes, and torque boxes and shock tower supports and core support brace. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: frame connectors on hemi car ? [Re: astjp2] #1396806
03/03/13 10:22 PM
03/03/13 10:22 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Yes.
Stan
Re: frame connectors on hemi car ? [Re: HemiStan] #1396807
03/03/13 10:33 PM
03/03/13 10:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Unless you want it to be completely accurate, it's a good idea to stiffen the structure. The '68-'70 bodies will flex and crack at a couple of areas, and from what I can tell the earlier cars aren't any stronger. If you never hammer it, it's probably not a concern, but...
Re: frame connectors on hemi car ? [Re: topside] #1396808
03/03/13 10:55 PM
03/03/13 10:55 PM
saint paul mn.
saint paul mn.
O.k. so has anyone seen damage or stressed body panels on a street only car ??? Really ???
Re: frame connectors on hemi car ? [Re: johnzgarage] #1396809
03/03/13 10:58 PM
03/03/13 10:58 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Just dont open a door with one corner on a jack, it will also help the suspension work and eliminate body flex with the extra weight of the Hemi.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: frame connectors on hemi car ? [Re: johnzgarage] #1396810
03/03/13 11:01 PM
03/03/13 11:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes... Cracks in the drivers quarter panel at the top by the door jamb.. I've fixed the cracks on three cars.. All were beaten hard in their early days... Never seen those cracks on cars that weren't used hard....
Re: frame connectors on hemi car ? [Re: 1_WILD_RT] #1396811
03/03/13 11:40 PM
03/03/13 11:40 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
It a clone, don't worry about it being 100% correct. Do it right the first time so you can bang on it later if you want.
Re: frame connectors on hemi car ? [Re: B5 Bee] #1396812
03/04/13 02:15 AM
03/04/13 02:15 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yes, on '68-'70 bodies I've seen cracks at the quarter panel door jamb area, the cowl, and once at the rear shock crossmember.
Re: frame connectors on hemi car ? [Re: 1_WILD_RT] #1396813
03/04/13 05:15 AM
03/04/13 05:15 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've seen quite a few A-bodies with cracks on the frame rail between near the upper control arm bushings supports. My 68 Conv Dart, Barracuda, and a good number of junkyard A-bodies with cracks there.
A-bodies also will seperate spot welds between the thick shock tower support and the inner fender.
My Barracuda is seperating between the firewall and floorpan spot welds. But my 71 Challenger had the same thing.
