which intake for 400cid mopar #1396652
03/03/13 02:48 PM
03/03/13 02:48 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Which intake you guys prefer for 400cid Mopar. Compression is 9.5, RacerBrown 220@.050" .484" lift 1200-5600RPM range hydraulic cam. Car is Valiant which is 80% street and 20% strip use
Single plane is no way to go but my choice would be Edelbrock Performer or Edelbrock Performer RPM...?
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: which intake for 400cid mopar [Re: Georg] #1396653
03/03/13 02:56 PM
03/03/13 02:56 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Low Blocks I've been around seem to run good with the old Torkers
Re: which intake for 400cid mopar [Re: 500ciDuster] #1396654
03/03/13 03:10 PM
03/03/13 03:10 PM
Cleveland, Ohio
BB73Challenger Offline
Cleveland, Ohio
The old Torkers and the old Holley Doms tested the best from what I re-call, but both are single plane.
As far as dual plane I believe the Eddy RPM's tested well.
I went with both the Torker and then opted for the Holley Dominator for my 500 - 400 based.
I BELIEVE they don't make the Holley for the low decks any more.
A 500 ci will pull well enough at any RPM you won't miss any low end running a single plane on the street.
Re: which intake for 400cid mopar [Re: Georg] #1396655
03/03/13 08:18 PM
03/03/13 08:18 PM
Gorge, is that 400 a SB, B or Gen 111 Hemi?If B motor I owuld try and get a Eddy Performer RPM for the torque and HP under 5000 RPM Try both a one and two inch spacer
Re: which intake for 400cid mopar [Re: Georg] #1396656
03/03/13 11:59 PM
03/03/13 11:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The Eddy RPM would be my intake of choice. The low deck RPM is a great intake choice for a b engine between 250 to 550 hp.
Re: which intake for 400cid mopar [Re: Cab_Burge] #1396657
03/04/13 05:49 AM
03/04/13 05:49 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
It`s 400 B
Re: which intake for 400cid mopar [Re: Georg] #1396658
03/04/13 09:42 AM
03/04/13 09:42 AM
maryland
74yellowduster Offline
maryland
with 9.5:1 that lil 400 will be pretty darn torquey no matter what intake you put on there. you better buy extra tires though.
Re: which intake for 400cid mopar [Re: 74yellowduster] #1396659
03/04/13 11:08 AM
03/04/13 11:08 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
performer rpm
Re: which intake for 400cid mopar [Re: dangina] #1396660
03/04/13 12:09 PM
03/04/13 12:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son uses the Performer RPM on the 400 in his mid 11 Dart. It works real good on it. Ron
