440 Source Super Stealth Heads #1396257
03/02/13 09:13 PM
03/02/13 09:13 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Any dyno, or flow testing of these heads? How good would they be for street and occasional 1/4 mile?
Re: 440 Source Super Stealth Heads [Re: RROD] #1396258
03/02/13 09:33 PM
03/02/13 09:33 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
The only info I have ever seen so far on the Super S , is in this post at bbdart.com I would take it with a grain of salt tho
http://www.bigblockdart.com/forum/showth...r-Stealth-do-it
Re: 440 Source Super Stealth Heads [Re: RROD] #1396259
03/02/13 09:33 PM
03/02/13 09:33 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Check the new Mopar Muscle, they ran some tests..
Out of the box, CNC ported vs. 915s.
Just my $0.02...
Re: 440 Source Super Stealth Heads [Re: Mopar-Al] #1396260
03/02/13 09:37 PM
03/02/13 09:37 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
T I would take it with a grain of salt tho
I call BS on the flow figures. Sorry, but dont see it happening...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440 Source Super Stealth Heads [Re: Von] #1396261
03/02/13 09:49 PM
03/02/13 09:49 PM
tboomer Offline
tboomer  Offline
Just an opinion but at 500.00 a head you have to figure the cost of valves and machine work. That adds up!
Re: 440 Source Super Stealth Heads [Re: Von] #1396262
03/02/13 10:05 PM
03/02/13 10:05 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Am I reading this right? To me this sheet is from a stock set of regular Stealth heads. I have tested 16 Stock out of the box ports and the most that I have found was 267cfm.
....................from OOTB...............to ported
.100"................73 cfm.....................80 cfm
.200"...............152.........................16 3
.300"...............214.........................22 0
.400"...............245.........................26 4
.450"............................................. 285
.500"...............262.........................30 1
.550"............................................. 313
.600"...............276.........................32 9
.650"............................................. 339
.700"...............281.........................34 1
.750"............................................. 343
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 Source Super Stealth Heads [Re: pittsburghracer] #1396263
03/02/13 11:36 PM
03/02/13 11:36 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
As I said, this has been the ONLY info I have ever found out from any source. I wasn't going to argue with the guy, and don't per say agree with his results, this is why I brought the post over to this thread. The head porters here, I was sure had some input on what that post and the guys numbers were said to represent.
Re: 440 Source Super Stealth Heads [Re: Mopar-Al] #1396264
03/03/13 12:12 AM
03/03/13 12:12 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Who cares.
They smell like fried rice
Re: 440 Source Super Stealth Heads [Re: pittsburghracer] #1396265
03/03/13 12:15 AM
03/03/13 12:15 AM
Idaho
LaRoy Engines Offline
Idaho
Yes they are flows from a regular Stealth head.
I have tested many stock Stealth ports and until recently the best they ever flowed OOTB was 268 cfm. The last three sets of heads have come hand blended in the bowls whereas they never have been before. This is what I attribute the OOTB increase in flows to.
On a Stealth port tested last night the flows were.
Lift.......Int/Exh
.100.........77/68
.200.......157/143
.300.......222/189
.400.......268/231
.500.......302/262
.600.......329/283
.700.......343/293
.750.......346/299
We have a junk Stealth port that flows 350 cfm @ .700" and 356 cfm @ .750" but gives up 6 cfm average through the 8 lifts.
I bought a pair of Super Stealth heads, just to test, because I had never seen any flow figures for them. Those are my flow test figures on BIGBLOCKDART.COM
Re: 440 Source Super Stealth Heads [Re: LaRoy Engines] #1396266
03/03/13 02:31 AM
03/03/13 02:31 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Heyold guy, the flow specs you listed here, that's for a regular Stealth? What level of work? Thanks. S/F....Ken M
Re: 440 Source Super Stealth Heads [Re: EchoSixMike] #1396267
03/03/13 12:50 PM
03/03/13 12:50 PM
Idaho
Idaho
Yes, that is for a regular Stealth. What would be your frame of reference for "level of work"? It's just enough work to get the listed flows.
Re: 440 Source Super Stealth Heads [Re: joshking440] #1396268
03/03/13 03:08 PM
03/03/13 03:08 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Who cares.
some people do.
and at least their customer service does'nt smell like crap......
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 440 Source Super Stealth Heads [Re: LaRoy Engines] #1396269
03/03/13 03:56 PM
03/03/13 03:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The last set of numbers you posted are obviously a ported set of stealths , CORRECT ?? And are they Stealth or Super Stealth ?
Still waiting to see a comparison of your work on another bench for a reference
Re: 440 Source Super Stealth Heads [Re: JohnRR] #1396270
03/03/13 05:26 PM
03/03/13 05:26 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
this is from my super stealth & my bench
been a while,been pretty ill,but the weather has cooled of some & finally got my flow bench & heads to the house,so i got some #s together so far,
these are the 440 super stealth & this is for a street motor,my testing cyl adapter is 4.250 bore diameter, i will machine it to 4.4 when i can get to it
otb .200 140
.300 202
.400 242
.500 256
.600 267
.700 267
OK opened the seat up a little & did a little combustion chamber work, worked on short side & made max wedge size i am stopping here cause i dont need more flow,this is a street engine build,@ .700 they flow enough to make 688 hp,my cam will be .650 lift. these heads really want a bigger valve but to do that the seats would have to be changed,flowing the head with no valve they flow 360 not saying they would flow that # with a bigger valve but the would definitely pick up some.
2.14 valve
.200 164
.300 217
.400 264
.500 290
.600 314
.700 335
.800 345
Re: 440 Source Super Stealth Heads [Re: Old School] #1396271
03/03/13 06:14 PM
03/03/13 06:14 PM
Idaho
Idaho
Who cares.
some people do.
Ditto, I've had nothing but excellent customer service from 440 Source.
Re: 440 Source Super Stealth Heads [Re: LaRoy Engines] #1396272
03/03/13 06:44 PM
03/03/13 06:44 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Frame of reference? Whatever you're comfortable with, I guess. What do you charge for that head at that flow would be my 1st choice, so it can be factored against buying a different head. If it takes 5hrs per port, a bunch of welding and epoxy, so you're looking at $2k labor right off then it just makes more sense to go Victors or B-1's from the beginning. I mean for racing, it makes sense to do that anyways but the vast majority of mopar guys seem to want to squeeze a turnip for blood
BTW, thanks for posting, it seems that a lot of folks want to attack you, for whatever reason, and I appreciate that you keep going. S/F.....Ken M
Re: 440 Source Super Stealth Heads [Re: JohnRR] #1396273
03/03/13 07:00 PM
03/03/13 07:00 PM
Idaho
Idaho
Correct, the flows in the above post are a ported set of standard Stealth.
Here are 325cc CNC 440-1 and SUPER Stealth flows from our bench, (1) column is OOTB Indy CNC 325cc 440-1 (avg of 4 ports), (2) is OOTB SUPER Stealth, (3) is ported SUPER Stealth with a very lazy attempt at porting the exhaust. The exhaust port in the Super Stealth, in my opinion, is inferior to the standard Stealth.
Lift...........(1).............(2)..............(3)
.100........66/61.........72/61..........75/65
.200......141/114......147/124.......155/139
.300......212/163......208/161.......218/184
.400......267/207......250/190.......268/216
.500......309/241......276/207.......313/240
.600......347/267......280/217.......344/259
.700......360/285......280/224.......354/275
Re: 440 Source Super Stealth Heads [Re: LaRoy Engines] #1396274
03/03/13 10:19 PM
03/03/13 10:19 PM
Oreland Pa
clonedshaker+6 Offline
Oreland Pa
does anyone have a picture of the stealth heads next to 906's, 346's, 915's, or any of the good iron heads, im curious to see how "stealth" these heads actually are, i was tossing around the idea of getting the stealth heads that have been ported by modern cylinder head from 440source then getting better locks retainers and springs for my car over the factory iron heads, but the car still needs metal work so the engine combo is undecided besides 440 sixpack but i want as close to factory look as possible, and are these heads even worth getting for that matter
71 challenger 440 sixpack shaker *CLONE* (71challenger 440+6 shaker clone FAST/my HS grad present)
03 mustang Mach 1 (daily driver)
11.35 @ 121.5 4 SPEED on F60-15s w/ 6/32 tread
Re: 440 Source Super Stealth Heads [Re: joshking440] #1396275
03/03/13 10:29 PM
03/03/13 10:29 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Who cares.
Now Josh don't be mean Just because they do work for most people and 440 Source ARE GOOD PEOPLE TO DEAL WITH unlike Indy.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: 440 Source Super Stealth Heads [Re: slippery440] #1396276
03/03/13 11:06 PM
03/03/13 11:06 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Who cares.
it,s just more of the same old, same old, indy arrogance
