Re: 440 Source Super Stealth Heads
[Re: RROD]
#1396259
03/02/13 09:33 PM
03/02/13 09:33 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Check the new Mopar Muscle, they ran some tests.. Out of the box, CNC ported vs. 915s. Just my $0.02...
[Re: Mopar-Al]
#1396260
03/02/13 09:37 PM
03/02/13 09:37 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
T I would take it with a grain of salt tho
http://www.bigblockdart.com/forum/showth...r-Stealth-do-it
I call BS on the flow figures. Sorry, but dont see it happening...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: EchoSixMike]
#1396267
03/03/13 12:50 PM
03/03/13 12:50 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Heyold guy, the flow specs you listed here, that's for a regular Stealth? What level of work? Thanks. S/F....Ken M
Yes, that is for a regular Stealth. What would be your frame of reference for "level of work"? It's just enough work to get the listed flows.
[Re: joshking440]
#1396268
03/03/13 03:08 PM
03/03/13 03:08 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
Who cares.
They smell like fried rice
some people do.
and at least their customer service does'nt smell like crap......
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: LaRoy Engines]
#1396269
03/03/13 03:56 PM
03/03/13 03:56 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
The last set of numbers you posted are obviously a ported set of stealths , CORRECT ?? And are they Stealth or Super Stealth ?
Still waiting to see a comparison of your work on another bench for a reference
[Re: JohnRR]
#1396270
03/03/13 05:26 PM
03/03/13 05:26 PM
Posts: 2,857 Pattison Texas
CSK
Pattison Texas
this is from my super stealth & my bench
been a while,been pretty ill,but the weather has cooled of some & finally got my flow bench & heads to the house,so i got some #s together so far, these are the 440 super stealth & this is for a street motor,my testing cyl adapter is 4.250 bore diameter, i will machine it to 4.4 when i can get to it otb .200 140 .300 202 .400 242 .500 256 .600 267 .700 267 OK opened the seat up a little & did a little combustion chamber work, worked on short side & made max wedge size i am stopping here cause i dont need more flow,this is a street engine build,@ .700 they flow enough to make 688 hp,my cam will be .650 lift. these heads really want a bigger valve but to do that the seats would have to be changed,flowing the head with no valve they flow 360 not saying they would flow that # with a bigger valve but the would definitely pick up some. 2.14 valve .200 164 .300 217 .400 264 .500 290 .600 314 .700 335 .800 345
[Re: Old School]
#1396271
03/03/13 06:14 PM
03/03/13 06:14 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Who cares.
some people do.
Ditto, I've had nothing but excellent customer service from 440 Source.
[Re: LaRoy Engines]
#1396272
03/03/13 06:44 PM
03/03/13 06:44 PM
Posts: 490 IL
EchoSixMike
IL
Frame of reference? Whatever you're comfortable with, I guess. What do you charge for that head at that flow would be my 1st choice, so it can be factored against buying a different head. If it takes 5hrs per port, a bunch of welding and epoxy, so you're looking at $2k labor right off then it just makes more sense to go Victors or B-1's from the beginning. I mean for racing, it makes sense to do that anyways but the vast majority of mopar guys seem to want to squeeze a turnip for blood
BTW, thanks for posting, it seems that a lot of folks want to attack you, for whatever reason, and I appreciate that you keep going. S/F.....Ken M
[Re: JohnRR]
#1396273
03/03/13 07:00 PM
03/03/13 07:00 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Correct, the flows in the above post are a ported set of standard Stealth.
Here are 325cc CNC 440-1 and SUPER Stealth flows from our bench, (1) column is OOTB Indy CNC 325cc 440-1 (avg of 4 ports), (2) is OOTB SUPER Stealth, (3) is ported SUPER Stealth with a very lazy attempt at porting the exhaust. The exhaust port in the Super Stealth, in my opinion, is inferior to the standard Stealth.
Lift...........(1).............(2)..............(3)
.100........66/61.........72/61..........75/65 .200......141/114......147/124.......155/139 .300......212/163......208/161.......218/184 .400......267/207......250/190.......268/216 .500......309/241......276/207.......313/240 .600......347/267......280/217.......344/259 .700......360/285......280/224.......354/275
