No spark electronic ignition. #139613
10/21/08 02:58 PM
10/21/08 02:58 PM
Ontario, Canada
jrn88 Offline OP
jrn88  Offline OP
Ontario, Canada
I have just converted my car to electronic ignition and I have wired everything up. It is a 5 pin system and I have got the new 4 post balast resistor on. Motor turns over but doesnt want to fire. Any tips on where the problem might lie?
Re: No spark electronic ignition. [Re: jrn88] #139614
10/21/08 03:00 PM
10/21/08 03:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do you have voltage to the coil + with the key in the run postion and in the start position? Have you tried turning the key on and then jumping the starter relay to see if it would start. That bypasses the start position on the ignition switch. You need to tell us what you've done to diagnose the trouble.
Re: No spark electronic ignition. [Re: stumpy] #139615
10/21/08 03:03 PM
10/21/08 03:03 PM
Ontario, Canada
jrn88 Offline OP
jrn88  Offline OP
Ontario, Canada
I think it isnt getting any spark I have power to the coil.
Re: No spark electronic ignition. [Re: jrn88] #139616
10/21/08 07:43 PM
10/21/08 07:43 PM
you might hook a jumper wire to the coil neg & ground it & pull it away & see if the coil wire produces a spark(w key on). post how you wired it up.
Re: No spark electronic ignition. [Re: jrn88] #139617
10/21/08 07:57 PM
10/21/08 07:57 PM
USA
V
VS29H0B Offline
VS29H0B  Offline
V
USA
Check that the ECU control box is WELL grounded, whereever you have it mounted. Remove the paint at the points where the attachment screws mount to the control box and the mounting surface, to ensure a good ground.
Also, you should check the air gap in the distributor, between the reluctor and the signal wheel. You must use a non-magnetic feeler gauge to check the air gap.
Like the women I have dated --- Always looking for a better deal ....
