BEST COUPLER FOR GTX??? #1395890
03/02/13 01:06 AM
03/02/13 01:06 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I am switching from factory power steering..to factory manual gear box. What would be the best coupler to use for this modification? I definately want to eliminate the factory "rag joint"! Thanks for the suggestions in advance! Randy B.
Re: BEST COUPLER FOR GTX??? [Re: Labratt] #1395891
03/02/13 01:20 AM
03/02/13 01:20 AM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
id call borgeson see if they make an adaptor, but the ps shaft is shorter so you will prob need to find a ms shaft and then modify it to a borgeson joint...I dont know of a way to eliminate the coupler and go to a better unit without making that shaft longer...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: BEST COUPLER FOR GTX??? [Re: pnypwr] #1395892
03/02/13 07:28 AM
03/02/13 07:28 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i just used the flamming river u-joint,didnt have to lenghten the shaft.
Re: BEST COUPLER FOR GTX??? [Re: bonefish] #1395893
03/02/13 10:45 AM
03/02/13 10:45 AM
west palm beach, florida
modelmakerinc Offline
The steering shaft will be to short with the swap to a manual box. I used borgenson a splined /smooth coupler, 3/4" rod and a splined /smooth steering u-joint.
slide the coupler on the box the u joint on the steering shaft and cut the shaft to lenght. weld them uo and you are done sir.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: BEST COUPLER FOR GTX??? [Re: modelmakerinc] #1395894
03/02/13 11:21 AM
03/02/13 11:21 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
just get this KIT from flamming river,no muss no fuss NO WELDING,itcomes with a extention and a u-joint.
Re: BEST COUPLER FOR GTX??? [Re: Labratt] #1395895
03/02/13 11:51 AM
03/02/13 11:51 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Factory rag joint ? ?????
Re: BEST COUPLER FOR GTX??? [Re: JohnRR] #1395896
03/02/13 11:52 AM
03/02/13 11:52 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i noticed that too,but I knew what he ment.
Re: BEST COUPLER FOR GTX??? [Re: bonefish] #1395897
03/02/13 02:10 PM
03/02/13 02:10 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
What are the negatives when replacing the factory "pot" type connector with a universal joint?
This is the land of the free because of the brave
Re: BEST COUPLER FOR GTX??? [Re: rbstroker] #1395898
03/02/13 03:11 PM
03/02/13 03:11 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I don't believe there's any problem other than if you installed it solid that won't allow any in and out movement of column to box. It's got to allow some "slip", like the above image that has the missing set screw maybe.
Re: BEST COUPLER FOR GTX??? [Re: buildanother] #1395899
03/02/13 04:23 PM
03/02/13 04:23 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Yeah, I thought that there must be some way to provide a bit of "give". That's why driveshafts have slip yokes and universals. I might be a bit concerned with the set screw missing though.
Re: BEST COUPLER FOR GTX??? [Re: rbstroker] #1395900
03/02/13 04:45 PM
03/02/13 04:45 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The drive shaft has a slip yoke because it needs to move rearward as the suspension drops.
A steering column does not have the problem but it needs to slip a little during installation and a tiny bit with chassis flex.
Cars with rubber isolated K frames or body on frame assemblies need slip in the steering shaft to allow for body flex.
- Stu Harmon
Re: BEST COUPLER FOR GTX??? [Re: feets] #1395901
03/02/13 10:15 PM
03/02/13 10:15 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive been meanin to replace that set screw.
Re: BEST COUPLER FOR GTX??? [Re: bonefish] #1395902
03/03/13 01:16 AM
03/03/13 01:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I could be wrong but I seem to remember that the shaft will slide out enough to connect to the manual box. The collapsible shaft has a nylon pin that shears during a crash. You can snap it off and pull the shaft outward.
Doug
Re: BEST COUPLER FOR GTX??? [Re: dvw] #1395903
03/04/13 10:23 AM
03/04/13 10:23 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for your help,guys! I will be playing around with the steering some time this week. Gotta get the X back on the road this season...after sitting out 2012,due to lack of funds to purchase needed trim pieces,and various NEW parts. Randy B.
Re: BEST COUPLER FOR GTX??? [Re: Labratt] #1395904
03/04/13 10:43 AM
03/04/13 10:43 AM
please let us know with pics of how you did the mod. good luck.
Re: BEST COUPLER FOR GTX??? [Re: modelmakerinc] #1395905
03/05/13 10:10 PM
03/05/13 10:10 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Henry!...I will!
Re: BEST COUPLER FOR GTX??? [Re: Labratt] #1395906
03/07/13 09:19 PM
03/07/13 09:19 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Not sure of the year, but the coupler in some of the older vans should do the trick.
Re: BEST COUPLER FOR GTX??? [Re: 1fastrunner] #1395907
03/07/13 10:09 PM
03/07/13 10:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Randy on my 63 I bought this adapter from Mancini as I think it was a Flaming River piece. I used my stock joint over as it was in great shape. This setup has worked fine for me.
And you car looks great Ron
