#1395890 - 03/01/13 10:06 PM BEST COUPLER FOR GTX???
Labratt Offline
Good Ol Randy B!
Loc: Clinton Twp... north of Deetro...
I am switching from factory power steering..to factory manual gear box. What would be the best coupler to use for this modification? I definately want to eliminate the factory "rag joint"! Thanks for the suggestions in advance! Randy B.
'69' STREET/STRIP GTX RON WILSON/DWAYNE PORTER CAMMED '448' PUMP-GAS WEDGE..w/Edelbrock heads cnc-ported by Jeff K.@ Modern Cylinder Head 11.19 @ 120 MPH.
#1395891 - 03/01/13 10:20 PM Re: BEST COUPLER FOR GTX??? [Re: Labratt]
pnypwr Offline
Loc: connecticut
id call borgeson see if they make an adaptor, but the ps shaft is shorter so you will prob need to find a ms shaft and then modify it to a borgeson joint...I dont know of a way to eliminate the coupler and go to a better unit without making that shaft longer...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
#1395892 - 03/02/13 04:28 AM Re: BEST COUPLER FOR GTX??? [Re: pnypwr]
bonefish Offline
Loc: s.w.fl
i just used the flamming river u-joint,didnt have to lenghten the shaft.
#1395893 - 03/02/13 07:45 AM Re: BEST COUPLER FOR GTX??? [Re: bonefish]
modelmakerinc Offline
Loc: west palm beach, florida
The steering shaft will be to short with the swap to a manual box. I used borgenson a splined /smooth coupler, 3/4" rod and a splined /smooth steering u-joint.
slide the coupler on the box the u joint on the steering shaft and cut the shaft to lenght. weld them uo and you are done sir.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
#1395894 - 03/02/13 08:21 AM Re: BEST COUPLER FOR GTX??? [Re: modelmakerinc]
bonefish Offline
Loc: s.w.fl
just get this KIT from flamming river,no muss no fuss NO WELDING,itcomes with a extention and a u-joint.
#1395895 - 03/02/13 08:51 AM Re: BEST COUPLER FOR GTX??? [Re: Labratt]
JohnRR Offline
Loc: U.S.S.A.
Factory rag joint ? ?????
#1395896 - 03/02/13 08:52 AM Re: BEST COUPLER FOR GTX??? [Re: JohnRR]
bonefish Offline
Loc: s.w.fl
i noticed that too,but I knew what he ment.
Edited by bonefish (03/02/13 08:53 AM)
#1395897 - 03/02/13 11:10 AM Re: BEST COUPLER FOR GTX??? [Re: bonefish]
rbstroker Offline
Loc: West Tennessee
What are the negatives when replacing the factory "pot" type connector with a universal joint?
This is the land of the free because of the brave
#1395898 - 03/02/13 12:11 PM Re: BEST COUPLER FOR GTX??? [Re: rbstroker]
buildanother Offline
Loc: chicagoland,usa
I don't believe there's any problem other than if you installed it solid that won't allow any in and out movement of column to box. It's got to allow some "slip", like the above image that has the missing set screw maybe.
#1395899 - 03/02/13 01:23 PM Re: BEST COUPLER FOR GTX??? [Re: buildanother]
rbstroker Offline
Loc: West Tennessee
Yeah, I thought that there must be some way to provide a bit of "give". That's why driveshafts have slip yokes and universals. I might be a bit concerned with the set screw missing though.
#1395900 - 03/02/13 01:45 PM Re: BEST COUPLER FOR GTX??? [Re: rbstroker]
feets Offline
Senior Management
Loc: Irving, TX
The drive shaft has a slip yoke because it needs to move rearward as the suspension drops.
A steering column does not have the problem but it needs to slip a little during installation and a tiny bit with chassis flex.
Cars with rubber isolated K frames or body on frame assemblies need slip in the steering shaft to allow for body flex.
#1395901 - 03/02/13 07:15 PM Re: BEST COUPLER FOR GTX??? [Re: feets]
bonefish Offline
Loc: s.w.fl
ive been meanin to replace that set screw.
#1395902 - 03/02/13 10:16 PM Re: BEST COUPLER FOR GTX??? [Re: bonefish]
dvw Offline
Loc: MI, usa
I could be wrong but I seem to remember that the shaft will slide out enough to connect to the manual box. The collapsible shaft has a nylon pin that shears during a crash. You can snap it off and pull the shaft outward.
Doug
#1395903 - 03/04/13 07:23 AM Re: BEST COUPLER FOR GTX??? [Re: dvw]
Labratt Offline
Good Ol Randy B!
Thanks for your help,guys! I will be playing around with the steering some time this week. Gotta get the X back on the road this season...after sitting out 2012,due to lack of funds to purchase needed trim pieces,and various NEW parts. Randy B.
#1395904 - 03/04/13 07:43 AM Re: BEST COUPLER FOR GTX??? [Re: Labratt]
please let us know with pics of how you did the mod. good luck.
#1395905 - 03/05/13 07:10 PM Re: BEST COUPLER FOR GTX??? [Re: modelmakerinc]
Labratt Offline
Good Ol Randy B!
Thanks,Henry!...I will!
#1395906 - 03/07/13 06:19 PM Re: BEST COUPLER FOR GTX??? [Re: Labratt]
1fastrunner Offline
Loc: Hunt Valley, Maryland
Not sure of the year, but the coupler in some of the older vans should do the trick.
#1395907 - 03/07/13 07:09 PM Re: BEST COUPLER FOR GTX??? [Re: 1fastrunner]
383man Offline
Loc: Balt. Md
Randy on my 63 I bought this adapter from Mancini as I think it was a Flaming River piece. I used my stock joint over as it was in great shape. This setup has worked fine for me.
And you car looks great Ron
My car...63 Sport Fury Max Wedge wanna be street car..with new 493 pump gas full exh eng.......10.76 @ 124.49 ! ! ! My page on the cool 62-65 Mopar site ! http://www.1962to1965mopar.ornocar.com/mmo82008.html
25,741 Registered Members
192,936 Topics
WIW: Stock LA Motor Connecting Rods
by vinnyd76
02/19/19 12:12 PM
What would win, road grader vrs MGB?
by GODSCOUNTRY340
02/19/19 12:03 PM
EMISSIONS CODE P0440
by moparsquid
02/19/19 11:30 AM
Brake calipers
by scottyb1955
02/19/19 11:17 AM
