Re: BEST COUPLER FOR GTX???
[Re: Labratt]
#1395891
03/02/13 01:20 AM
03/02/13 01:20 AM
Posts: 4,872 connecticut
pnypwr
connecticut
id call borgeson see if they make an adaptor, but the ps shaft is shorter so you will prob need to find a ms shaft and then modify it to a borgeson joint...I dont know of a way to eliminate the coupler and go to a better unit without making that shaft longer...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: Labratt]
#1395895
03/02/13 11:51 AM
03/02/13 11:51 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
I am switching from factory power steering..to factory manual gear box. What would be the best coupler to use for this modification? I definately want to eliminate the factory "rag joint"! Thanks for the suggestions in advance! Randy B.
Factory rag joint ? ????? ![](/ubbthreads/images/graemlins/confused.gif)
[Re: buildanother]
#1395899
03/02/13 04:23 PM
03/02/13 04:23 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Yeah, I thought that there must be some way to provide a bit of "give". That's why driveshafts have slip yokes and universals. I might be a bit concerned with the set screw missing though.
This is the land of the free
because of the brave
[Re: rbstroker]
#1395900
03/02/13 04:45 PM
03/02/13 04:45 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The drive shaft has a slip yoke because it needs to move rearward as the suspension drops.
A steering column does not have the problem but it needs to slip a little during installation and a tiny bit with chassis flex. Cars with rubber isolated K frames or body on frame assemblies need slip in the steering shaft to allow for body flex.
