Re: small block guru's help 340/360????'s
[Re: 70rrclone]
#139559
10/21/08 02:11 PM
10/21/08 02:11 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
depends on the compression height of the pistons...the low compression 340 pistons can be milled to fit...but you will have a high compression 360 then... also...the 360 block will need to be sonic checked before boring .070..
it would be far easier to sell the 340 pistons and buy the correct 360 pistons...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
