6.1 HEMI IGNITION #1395152
02/28/13 06:42 PM
02/28/13 06:42 PM
OHIO
BUBBAZ572 Offline OP
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
2009 6.1 ENGINE
WHO MAKES THE BEST IGNITION SYSTEM?
NEED TO CONTROL THE ENGINE AND TRANS.
Re: 6.1 HEMI IGNITION [Re: BUBBAZ572] #1395153
03/01/13 09:26 AM
03/01/13 09:26 AM
NY usa
540challenger Offline
NY usa
There are plenty of aftermarket controls for the engine however if you want to use the factory transmission i think you are going to be using the oem computer
Re: 6.1 HEMI IGNITION [Re: 540challenger] #1395154
03/04/13 03:20 PM
03/04/13 03:20 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
THATS GREAT BUT I NEED A BRAND NAME
Re: 6.1 HEMI IGNITION [Re: BUBBAZ572] #1395155
03/04/13 09:17 PM
03/04/13 09:17 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Bubba,
Look at MSD ignition. You can use a MSD controller for the ignition without the EFI, and just run the carb.
http://www.msdignition.com/MoparLP.aspx
FAST EFI also makes a stand alone Efi kit for 3000 for almost everything.
I do not make harnesses as I cannot make any money at it.
Call HOTWIREAUTO.com they have the nicest harness in my opinion,but $1000 for it.
justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 6.1 HEMI IGNITION [Re: wldtm] #1395156
03/06/13 12:24 PM
03/06/13 12:24 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The FAST XIM kit will run this engine in the standalone mode (without EFI). Or you could replace the OEM computer and run the FAST XFI with the XIM ignition controller and have total control of everything. Fast has a kit for both applications and the trans controller would come from TCI.
Re: 6.1 HEMI IGNITION [Re: wldtm] #1395157
03/09/13 10:15 PM
03/09/13 10:15 PM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Bubba,
justin
only a grand?
$1500 to make mine for the Dakota
who is that guy?
