93 350 CTD...adding 2nd battery? #1394617
02/28/13 02:15 AM
02/28/13 02:15 AM
Phoenix, AZ
MoparBilly Offline OP
Phoenix, AZ
Seems I'm constantly fighting to keep enough battery in my truck. The 12 Valve and killer stereo system and pulling trailers...so I'd like to add a second battery...any aftermarket kits to do this, or will I have to fab it up myself??
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 93 350 CTD...adding 2nd battery? [Re: MoparBilly] #1394618
02/28/13 02:45 AM
02/28/13 02:45 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Im not sure about the kits, but is your truck using an actual diesel rated battery? It seems that many parts stores are selling a non-diesel battery in place of the OEM type replacement.
Not sure why, but as an example O'Reilly's doesn't even list a battery for the 93 CTD trucks. So they often just sell the group 27 battery to customers.
I don't know if there would be room on the passenger side near the air box or not for a second. My truck had a second battery on the frame rail under the box, a fabbed battery box was attached to the frame, and lead wires ran along the inner frame rail, up to the main battery.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 93 350 CTD...adding 2nd battery? [Re: MoparBilly] #1394619
02/28/13 09:49 AM
02/28/13 09:49 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Are you running a group 31 battery? The interstate part would be 31P-MHD which is a 950CCA. You might actually be able to go down some in CCA to help increase service life since you live in AZ, an Interstate part for that would be a 31P-LHD 750CCA. I work for interstate in case you couldn't tell, but those part numbers should be easily crossed by anyone.
I had a 92 for awhile that had a 6 year old battery in it and it started fine even in single digit temps. It lacked the killer stereo though.
With as easy as those rotary pump motors start you could probably just hang a hand crank out the front that you could kick before you get in . My friends and I joked that you could start my old 92 beater by hitting the alternator pulley with a hammer lol.
68 Barracuda Formula S 340
Re: 93 350 CTD...adding 2nd battery? [Re: Bad340fish] #1394620
02/28/13 01:54 PM
02/28/13 01:54 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Hey Bad340fish,
Does Interstate make a dual terminal in a group 31 or a group 27?
Im looking for one to replace the discontinued Super Start Premium that went bad.
Re: 93 350 CTD...adding 2nd battery? [Re: MoparBilly] #1394621
02/28/13 09:59 PM
02/28/13 09:59 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
If your alternator can't keep up then eventually you will kill the 2nd battery. They should also be matched (new) if you go thru with it.
Re: 93 350 CTD...adding 2nd battery? [Re: redraptor] #1394622
02/28/13 10:44 PM
02/28/13 10:44 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
A battery isolator is something to consider as well.
It will also help to prevent total loss of both batteries. Say you wire a pair up parallel to get a dual battery feed to power the vehicle electronics, and the second for the accessories, they all share the battery power.
If you leave the lights on, or run the stereo too long you could possibly drain the batteries to the point they would leave you stranded.
With the isolator, the vehicle power can be isolated from the accessories, then if you drain one battery, you still have the other to get you going again.
Re: 93 350 CTD...adding 2nd battery? [Re: MoparBilly] #1394623
02/28/13 11:23 PM
02/28/13 11:23 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have the same issue with my 93. Nobody makes the right battery anymore, I am using a group 65 that was in my 2004, but of course there are two of them. I will be watching this thread and I WILL buy one of those isolators as I have a battery on the back of my ramp truck to run the winch and it is cabled to the start battery.
JB Rhinehart, Realist
A-Body's RULE!
Re: 93 350 CTD...adding 2nd battery? [Re: Rhinodart] #1394624
02/28/13 11:30 PM
02/28/13 11:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Go to interstate and use the part numbers I mentioned above. I usually have over 40 on hand and I would guess the same around the country. Any farm supply should carry that style.
Re: 93 350 CTD...adding 2nd battery? [Re: hp383] #1394625
02/28/13 11:32 PM
02/28/13 11:32 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Hey Bad340fish,
Nope no dual terminal. You could use a marine 27 cranking battery and have an automotive post and a 5/16th stud.
Re: 93 350 CTD...adding 2nd battery? [Re: Bad340fish] #1394626
03/01/13 04:48 AM
03/01/13 04:48 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
My buddy uses a semi truck battery in his 93. He also wants to add in a second battery but I think space is the issue.
Re: 93 350 CTD...adding 2nd battery? [Re: DaytonaTurbo] #1394627
03/01/13 11:39 AM
03/01/13 11:39 AM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
I run a group 31 Interstate battery in mine and its rated at 1125 CCA............I occasionally pull a single car hauler trailer and haul my travel trailer with it. I don't have a killer stereo but do have a portable winch for those just in case moments.No problems.
Re: 93 350 CTD...adding 2nd battery? [Re: Lugnutz] #1394628
03/03/13 10:39 PM
03/03/13 10:39 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
I'll have to go look, but on my 93 and my 85 I bought two 700 or 800 CCA batteries, and turned them sideways and put them on the same tray. I had to make a new hold down, and some short cables to tie the two batteries together. This way I end up with 1400 or 1600 CCA without trying to track down an expensive/elusive battery. Now both my trucks carry a relativly generic battery that away from home I should be able to find at nearly any parts store.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
