93 350 CTD...adding 2nd battery?
#1394617
02/28/13 02:15 AM
02/28/13 02:15 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Seems I'm constantly fighting to keep enough battery in my truck. The 12 Valve and killer stereo system and pulling trailers...so I'd like to add a second battery...any aftermarket kits to do this, or will I have to fab it up myself??
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
Re: 93 350 CTD...adding 2nd battery?
[Re: MoparBilly]
#1394618
02/28/13 02:45 AM
02/28/13 02:45 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Im not sure about the kits, but is your truck using an actual diesel rated battery? It seems that many parts stores are selling a non-diesel battery in place of the OEM type replacement.
Not sure why, but as an example O'Reilly's doesn't even list a battery for the 93 CTD trucks. So they often just sell the group 27 battery to customers.
I don't know if there would be room on the passenger side near the air box or not for a second. My truck had a second battery on the frame rail under the box, a fabbed battery box was attached to the frame, and lead wires ran along the inner frame rail, up to the main battery.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: Bad340fish]
#1394620
02/28/13 01:54 PM
02/28/13 01:54 PM
hp383
State of Confusion
Hey Bad340fish,
Does Interstate make a dual terminal in a group 31 or a group 27?
Im looking for one to replace the discontinued Super Start Premium that went bad.
[Re: MoparBilly]
#1394621
02/28/13 09:59 PM
02/28/13 09:59 PM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
If your alternator can't keep up then eventually you will kill the 2nd battery. They should also be matched (new) if you go thru with it.
[Re: redraptor]
#1394622
02/28/13 10:44 PM
02/28/13 10:44 PM
hp383
State of Confusion
A battery isolator is something to consider as well.
It will also help to prevent total loss of both batteries. Say you wire a pair up parallel to get a dual battery feed to power the vehicle electronics, and the second for the accessories, they all share the battery power.
If you leave the lights on, or run the stereo too long you could possibly drain the batteries to the point they would leave you stranded.
With the isolator, the vehicle power can be isolated from the accessories, then if you drain one battery, you still have the other to get you going again.
[Re: Lugnutz]
#1394628
03/03/13 10:39 PM
03/03/13 10:39 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I'll have to go look, but on my 93 and my 85 I bought two 700 or 800 CCA batteries, and turned them sideways and put them on the same tray. I had to make a new hold down, and some short cables to tie the two batteries together. This way I end up with 1400 or 1600 CCA without trying to track down an expensive/elusive battery. Now both my trucks carry a relativly generic battery that away from home I should be able to find at nearly any parts store.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
