Re: Block clearance for 408 stroker & H beam rods
[Re: mshred]
#1394583
02/28/13 12:41 AM
02/28/13 12:41 AM
Triple Threat
Renton Washington
If you have a standard size rod journal you'll probably need a small notch at the bottom of the bore for the rod bolt. If you have a chevy sized rod journal, you might be able to sneak by with no notch. Regardless, best to mock it up and check. All blocks are bit different
