Block clearance for 408 stroker & H beam rods #1394581
02/28/13 12:32 AM
02/28/13 12:32 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey guys,
Just about ready to mock up my 360 block with the new 4" crank and scat H beams, and I was wondering where, if at all, I would have to clearance the block? If anybody has pictures that would be great as well! Thanks!
Re: Block clearance for 408 stroker & H beam rods [Re: mshred] #1394582
02/28/13 12:40 AM
02/28/13 12:40 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
You'll have to mock it up but on mine the spot to look for was where the bottom of the cylinder might get clipped by the rod bolt area as the big arm swings by.
Re: Block clearance for 408 stroker & H beam rods [Re: mshred] #1394583
02/28/13 12:41 AM
02/28/13 12:41 AM
Renton Washington
Triple Threat Offline
Renton Washington
If you have a standard size rod journal you'll probably need a small notch at the bottom of the bore for the rod bolt.
If you have a chevy sized rod journal, you might be able to sneak by with no notch.
Regardless, best to mock it up and check. All blocks are bit different
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Block clearance for 408 stroker & H beam rods [Re: mshred] #1394584
02/28/13 11:04 AM
02/28/13 11:04 AM
Az
Crizila Offline
Crizila  Offline
Az
Hey guys,
Here ya go.
Fastest 300
Re: Block clearance for 408 stroker & H beam rods [Re: mshred] #1394585
03/01/13 08:16 AM
03/01/13 08:16 AM
BPE Offline
BPE  Offline
As stated above each block is different. The only way is mock it up and see how much needs to be removed. The regular scat H beams are rediculously big and bulky and IIRC the last set I had here were around 715 grams. Good luck with your build Matthew.
Rod
Re: Block clearance for 408 stroker & H beam rods [Re: BPE] #1394586
03/01/13 05:56 PM
03/01/13 05:56 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey guys, thanks for the pictures and info! I was not going to just chance it, and definitely mock it up first. Just wanted to get an idea of how much I should expect to grind off the block, and where abouts I would be grinding. Is there a certain amount of clearance I should be shooting for?
And yes Rod, I am using the Scat H beams with ARP 2000 bolts in them, definitely a PHAT ASS piece for sure lol
