home ported heads #1394250
02/27/13 03:39 AM
02/27/13 03:39 AM
pennsylvania
poboyengineering Offline OP
pennsylvania
a couple of observations while porting my heads in the basement:
1)it takes a lot longer than you planned.
2)port to port consistency is very hard to achieve.
3)it looks good when you go to bed, and looks like crap the next day.
4)i almost forgot...im not as clever as i thought!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: home ported heads [Re: poboyengineering] #1394251
02/27/13 05:38 AM
02/27/13 05:38 AM
pennsylvania
pennsylvania
i broke through the pushrod pinchpoint...no surprise...what sort of epoxy will hold a tube to repair the leak?
Re: home ported heads [Re: poboyengineering] #1394252
02/27/13 07:40 AM
02/27/13 07:40 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
JB weld
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: home ported heads [Re: poboyengineering] #1394253
02/27/13 01:19 PM
02/27/13 01:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My first couple of ports reminded me of my first few beers and women; The women I took home looked great when I(we)went to bed(like your ports)but in the morning things were a bit different(like your ports again).......... You need some dividers and basic cheapo measuring tools(forgot what they`re called)from harbor freight or wherever so you can maintain port-to-port consistancy and good lighting is VERY important...........
Re: home ported heads [Re: poboyengineering] #1394254
02/27/13 01:30 PM
02/27/13 01:30 PM
Washington
SuperStock68Dart Offline
Washington
Splash Zone....the best you will find in epoxy for cylinder heads!
Re: home ported heads [Re: SuperStock68Dart] #1394255
02/27/13 01:40 PM
02/27/13 01:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
if you don't have experience and a way to check what you do flow wise you will probably cause more harm than help
Re: home ported heads [Re: SuperStock68Dart] #1394256
02/27/13 01:46 PM
02/27/13 01:46 PM
dogdays Offline
dogdays  Offline
Every time I go to the dentist I think about porting heads.
For my 302 heads I wore earplugs and a dust mask. The Sears electric die grinder came with a long cylindrical stone so I used that. It quickly wore down to a flame shape. I spent most of the time in the bowls, opening up around the valve guide and smoothing transitions. The pushrod pinch I was leery of but I did trim it some, and I got the port faces out to nearly 360 size, paying more attention to which side of the port was more important. I think it took about 8 hours. Being outside and use of earplugs makes it better.
You are right, going over the job the next day, one sees all sorts of little problems.
Congratulations on giving it a try!
R.
Re: home ported heads [Re: dogdays] #1394257
02/27/13 02:52 PM
02/27/13 02:52 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I dont know if imissed it somwewhere but what kind of heads are you porting? I home ported a set of 906's mainly the bowls and cleaned them up and they seemed to work pretty good. I used the porting templates in the bowls from mopar performance.
67' charger 499 RB 10.57 at 127
Re: home ported heads [Re: SuperStock68Dart] #1394258
02/27/13 03:48 PM
02/27/13 03:48 PM
PA.
"Little"John
"Little"John
PA.
Splash zone is way over kill for holding tubes in. I drill mine out to the tubing size apply a little JB weld and its ready. When you tap it in it wipes of about 90% of it any way. If it is a small block Edelbrock get some 17/32 K&S brass tube #140 from Ace Hardware. If you need more info PM me. I just did 12 holes last night.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: home ported heads [Re: poboyengineering] #1394259
02/27/13 04:59 PM
02/27/13 04:59 PM
pennsylvania
pennsylvania
thanks for the info..btw, these are 308 sb heads (ive only got $20 in them at this point, so im not scared!) the swirl port thing sort of worries me..it looks like they take up a lot of room, and the serious heads dont have them. any advice? my hillbilly way of checking these is to cc the ports...best i can do right now. with any luck ill only slow it down .25 sec...lol
Re: home ported heads [Re: pittsburghracer] #1394260
02/27/13 05:03 PM
02/27/13 05:03 PM
Washington
Washington
If your pressing a tube into a hole why not just use Loctite sleeve retainer? I didn't know what heads he was using, he didn't say that in his post....my heads dont have a hole to press a tube into...and didn't know his did. Sorry for the misunderstanding!
Re: home ported heads [Re: SuperStock68Dart] #1394261
02/27/13 05:50 PM
02/27/13 05:50 PM
dogdays Offline
dogdays  Offline
The "story" on the 308s is that the exhaust port is really good, the intake port is where you put the work. Use a single pattern camshaft when you're all done.
If you want to see a botched intake port look at chevy 350 heads casting 193, they have about half the intake bowl blocked off.
R.
Re: home ported heads [Re: dogdays] #1394262
02/27/13 05:53 PM
02/27/13 05:53 PM
pennsylvania
pennsylvania
yeah, dogdays..im grinning over the exhaust. really straight roof.
Re: home ported heads [Re: poboyengineering] #1394263
02/27/13 09:31 PM
02/27/13 09:31 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
keep up the good work . like you said 20 dollar heads have some fun and see what you can get out of them some people like the Moroso A-B epoxy.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: home ported heads [Re: WHITEDART] #1394264
02/27/13 10:28 PM
02/27/13 10:28 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
just press steel stock in the pushrod hole then re-drill to the w2 offset..then grind open the port shirt side square..
dont take anything off the floor unless you know what your doing at the short turn. you will kill more flow there than make if its wrong..
Ive always added material on the short turn..
the radius is key and its easy to kill it and make the same air as an almost unported head..
good luck..
another trick is put a vacuume in the intake port from the comb chamber it will suck out all the debris as you grind..
some doans back pills or ibuprofen and youll will be in order though..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: home ported heads [Re: cheapstreetdustr] #1394265
02/28/13 12:08 AM
02/28/13 12:08 AM
PA.
"Little"John
"Little"John
PA.
I LOVE the taste of cast iron in the morning.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: home ported heads [Re: pittsburghracer] #1394266
02/28/13 12:19 AM
02/28/13 12:19 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Even with a mask on and the shop vac sucking chips from the opposite port - I have black buggers for a week.
Re: home ported heads [Re: Duner] #1394267
02/28/13 12:50 AM
02/28/13 12:50 AM
PA.
"Little"John
"Little"John
PA.
I would love to have one of these be I would have to start charging more. http://www.grizzly.com/products/28-x-39-Downdraft-Table/H2936
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: home ported heads [Re: poboyengineering] #1394268
02/28/13 02:36 PM
02/28/13 02:36 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
Years ago I spent ALOT of time on a pair of "J" heads........The single, most important thing I learned was; I should'a had them leak checked before I bolted them down.......it was a calculated risk I lost!
Hope your results are better than mine.......
Good luck!!
Re: home ported heads [Re: JBurch] #1394269
02/28/13 04:19 PM
02/28/13 04:19 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
I could always tell when a set was done "at home" by first glance. The first hole is always the largest....most work done. As the job progressed you could tell guy was getting bored and just wanted to get them "done". Each port would become progressively less and less "worked" until the final hole looked like a quickie polish job...no need to even flow...even if the first hole WAS done properly.... which they never are as they ALWAYS only "open them up" at the accessible areas...
