Paint repair/ scuff removal???? #1394007
02/26/13 04:08 PM
02/26/13 04:08 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
My mom came into town and stayed at my place last weekend while I was in Reno. Instead of renting a car, I let her borrow my truck. She wanted to do something nice by filling the tank and running it through a car wash. Needles to say, she cut the corner to tight entering the car wash and scrubbed the steel post protecting the money collecting machine. There aren't any dents, but some of the white paint form the post, scuffed up the bed side of my truck. I've tested a little area with my finger nail and some hand cleaner and it looks like it'll come off.
Do you guys have any recommendations on what to use to take the scuff off? It seems to just be latex paint transferred from the post. Using a buffer makes me nervous because most of the scuffs are on the wheel arch body lines.
Re: Paint repair/ scuff removal???? [Re: mopowers] #1394008
02/26/13 05:13 PM
02/26/13 05:13 PM
ohio
silverhemiboy Offline
ohio
just try some hand rubbing compound on a rag and buff and see what you can get off.
Re: Paint repair/ scuff removal???? [Re: silverhemiboy] #1394009
02/26/13 06:15 PM
02/26/13 06:15 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Is there a specific product you recommend?
Re: Paint repair/ scuff removal???? [Re: mopowers] #1394010
02/26/13 09:02 PM
02/26/13 09:02 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Lacquer thinner will take the transfered paint right off. As for the scratches that remain, depends on how deep they are.
Re: Paint repair/ scuff removal???? [Re: forphorty] #1394011
02/26/13 10:18 PM
02/26/13 10:18 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Daughter did the same thing on her Echo. Used 3M's Perfect-It 3000. Worked like a charm. You can use it by hand or with a buffer and sponge pad.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Paint repair/ scuff removal???? [Re: Dads426] #1394012
02/27/13 01:29 PM
02/27/13 01:29 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I'm going to go get some rubbing compound to try. But I do have some acetone I was thinking about trying. Do you think acetone would be too aggressive and cut into the clear coat on the truck?
Re: Paint repair/ scuff removal???? [Re: mopowers] #1394013
02/27/13 01:42 PM
02/27/13 01:42 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Use the Acetone... It's exactly what I was going to suggest when I first opened this thread..... My buddy owns a high end detail shop & deals with paint transfer frequently.. He always starts with acetone..
Re: Paint repair/ scuff removal???? [Re: 1_WILD_RT] #1394014
02/27/13 02:44 PM
02/27/13 02:44 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks. I'll give it a try this evening and see what happens.
Re: Paint repair/ scuff removal???? [Re: mopowers] #1394015
02/28/13 06:41 PM
02/28/13 06:41 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Acetone worked like a charm! There are still some tiny scratches in the clear coat I'll try to buff out with some compound. Chances are they will require some wet sanding, but either way, my mom is a lot happier. At this point, I'd rather live with the few tiny scratches than risk cutting through the clear and making it worse.
Re: Paint repair/ scuff removal???? [Re: mopowers] #1394016
03/02/13 07:54 PM
03/02/13 07:54 PM
Jacksonville Florida
elitecustombody Offline
I prefer lacquer thinner as it leaves no residue when it evaporates, acetone leaves residue. It also works great on tree sap,even hard like a rock sap.
Re: Paint repair/ scuff removal???? [Re: elitecustombody] #1394017
03/02/13 11:23 PM
03/02/13 11:23 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
We're in California, you can't buy real lacquer thinner here... The stuff you can buy costs 50% more & doesn't work.. I've imported Lacquer thinner the past two times I've been out on the road... You can still get the real stuff in Reno... $42 for 5 gallons...
