Isky Valve Springs, Thoughts on quality? #1393633
02/26/13 12:03 AM
02/26/13 12:03 AM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
I just found out today that my valve springs were down to 120lbs seat pressure and at least one was broken. These were double springs and obviously much higher pressure when new. In an attempt to get my heads put back together before this weekend I went to the local speed shop and picked up a set of Isky 9005 springs. The price was right and I was glad to support the local business.That being said does anybody have any yay or nay inputs on the Isky brand? I couldn't tell you off hand what my old springs were but the fact they are so weak and or broken after such low mileage is pretty disappointing. I hope the Isky's hold up better and are worth the money. Thoughts?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393634
02/26/13 12:11 AM
02/26/13 12:11 AM
WA
JD Dart Offline
JD Dart  Offline
WA
They are good springs Isky make good stuff.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393635
02/26/13 12:33 AM
02/26/13 12:33 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
A speed-shop that is LOCAL ? ...that is very rare these dayz.
Re: Isky Valve Springs, Thoughts on quality? [Re: JD Dart] #1393636
02/26/13 12:40 AM
02/26/13 12:40 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I run those same springs...
Re: Isky Valve Springs, Thoughts on quality? [Re: dOoC] #1393637
02/26/13 01:05 AM
02/26/13 01:05 AM
Tucson AZ,
Tucson AZ,
Only one left in town. They were cheaper than Summit too. I was very happy to find that pricing and in stock at that. Sounds like I won't be disappointed at this rate.
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393638
02/26/13 01:08 AM
02/26/13 01:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Isky use to make a very good spring... I havent used
them in years but if they are the same quality you wont
have any worries... all I use now days are PAC springs
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393639
02/26/13 01:10 AM
02/26/13 01:10 AM
Most valve springs don't break unless thier is a reason I have learn the hard way to set the valve springs up by pressure and always check for valve retainer and keepers to the valve seals and ALWAYS check for coil bind hieght versus max open hieghts I shoot for .060 to .100 between max lift hieghts and coil binds hieghts, I check all 16 valve springs and rockers for lift at the retainers Lots of gremlins out there, it only takes one to get you
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393640
02/26/13 01:10 AM
02/26/13 01:10 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been using Isky stuff for years and their stuff works for my needs and their tool-room line is tops in my books.............
Re: Isky Valve Springs, Thoughts on quality? [Re: Cab_Burge] #1393641
02/26/13 01:22 AM
02/26/13 01:22 AM
Tucson AZ,
Tucson AZ,
My Dad (RATKLR) called it before I did, when I mentioned that the motor quit pulling above 5600 he said I should get the springs checked before putting the motor back in. The wierd thing is they didn't seem to be floating or at least you couldn't tell easily if they were. E.T would just drop off. I'll talk to my machinist tomorrow to determine possible reason for failure. Just another reason to dream about how much faster the car will be when I get the motor back together. Thanks for all the input! I'll keep you guys posted.
Re: Isky Valve Springs, Thoughts on quality? [Re: Thumperdart] #1393642
02/26/13 01:23 AM
02/26/13 01:23 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Not 100 % sure if Isky does this,but most cam companies outsource their valve springs Just like flat tappets there are very few companies that actually make them but instead rebox them.
I know of several companies that all sell the same springs with different part numbers. Like I said,Isky may be different though.
Keith
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393643
02/26/13 03:08 AM
02/26/13 03:08 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I guess those springs are for a solid cam? 185# seat pressure?
I have the Isky 8005A springs on my hydraulic roller cam and so far no problems.
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393644
02/26/13 07:52 PM
02/26/13 07:52 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
You can't go wrong with Isky. All of there parts that I've owned are top quality. I have been running there Tool Room springs for 7 seasons now. They have only dropped 5-7 pounds of seat pressure max from the time I put them in.
Re: Isky Valve Springs, Thoughts on quality? [Re: 66er] #1393645
02/26/13 07:56 PM
02/26/13 07:56 PM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
I run the same spring.Three years no issues!I will be removing them in the next month to check them out along with other off season maintenance.They get the
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393646
02/26/13 10:06 PM
02/26/13 10:06 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Trent,
Kudos for DON'S HOTROD SHOP!They're the Best
[img] [/img]
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393647
02/26/13 10:45 PM
02/26/13 10:45 PM
NC
440Jim Offline
440Jim  Offline
NC
... picked up a set of Isky 9005 springs
I run Isky valve springs on my race, flat tappet, solid lifter engine. I think they are good.
My Indy 440-1 heads have the Isky 9005 springs setup at 1.95" (150 lbs) and my cam is 0.693" lift with 1.6 rockers.
Runs 9.20's at 3250 lbs. So I am happy.
Re: Isky Valve Springs, Thoughts on quality? [Re: 440Jim] #1393648
02/26/13 11:52 PM
02/26/13 11:52 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Isky 8005A springs in 2 motors, zero problems.
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393649
02/27/13 12:27 AM
02/27/13 12:27 AM
Tucson AZ,
Tucson AZ,
I think I'll be pretty happy with them. The machine shop wants to use different keepers because at approximately 1.9" installed height they are showing like 180lbs closed and 420lbs open. When the speed shop checked them they were showing 160lbs closed and 360lbs open at my installed height. A slight issue but assuming the the rockers don't hit the retainers I'm ok with using different keepers to get it in range. Then I can swap keepers mid season to get back to where I want to be before they wore in Lol. The speed shop was probably using a mechanical compressor compared to the computerized one at the machine shop. Kind of hard to say which one I trust. Anybody have input on the numbers I should be seeing with these springs? The cam is a MP 557 FWIW.
Re: Isky Valve Springs, Thoughts on quality? [Re: 440Jim] #1393650
02/27/13 12:32 AM
02/27/13 12:32 AM
Tucson AZ,
Tucson AZ,
I have HORRIBLE memory but I want to say mine are at 1.915. Should they be at 180lbs given that difference?
Re: Isky Valve Springs, Thoughts on quality? [Re: MadMopars] #1393651
02/27/13 12:43 AM
02/27/13 12:43 AM
I think I'll be pretty happy with them. The machine shop wants to use different keepers because at approximately 1.9" installed height they are showing like 180lbs closed. When the speed shop checked them they were showing 160lbs closed at my installed height. A slight issue but assuming the the rockers don't hit the retainers I'm ok with using different keepers to get it in range. The speed shop was probably using a mechanical compressor compared to the computerized one at the machine shop. Kind of hard to say which one I trust. Anybody have input on the numbers I should be seeing with these springs? The cam is a MP 557 FWIW.
Be very careful on the open pressures, check all the retainers lift, ALL 16 OF THEM Then check all the valve springs pressures at those lifts I've got a used set of 440-1 aluminum race heads in my shop now that have a set of 1.64 diameter roller cam springs and titainium retainers, the inner dampener is eating through the titainium retainers The person who asembled the heads set the valve springs up at the same hieght, not by pressure, something is really FUBAR on thses heads The spring pressures vary from 220 to 250 lbs on the seats of the four I have checked so far, 680 lbs at .700 to 750 lbs at .700 and they vary from .010 to .100 from coil bind at .700 lift I can fixed them, I have a wonderful set of tools I have PAC springs phone number
Re: Isky Valve Springs, Thoughts on quality? [Re: Cab_Burge] #1393652
02/27/13 09:28 AM
02/27/13 09:28 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
This is a very good advise since the springs are more stable near coil bind. Seems like people dwell to much on the installed height specs. Sometimes better to work backwards from the coil bind height and set the springs up.
I just got done looking at my Isky tool room springs 9985. Set these at about .100 from bind and saw very little spring load loss(Maybe 5 lbs) after 1200 street miles and some low 9, high 8 second passes.
FWIW - have a really nice bench top spring tester that is very accurate and much nicer than the Rimac I use to barrow.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
