R3 block 9.6 Deck vs 9.0 #1393160
02/24/13 11:23 PM
02/24/13 11:23 PM
South Carolina
SCMopar Offline OP
SCMopar  Offline OP
South Carolina
I currently have a 9.0 deck r3 block W8 motor and was wanting to go to a 9.2 or 9.6 block to get a longer stroke. I was wondering what parts will not fit on the taller deck blocks?
Thank you
Re: R3 block 9.6 Deck vs 9.0 [Re: SCMopar] #1393161
02/25/13 10:07 AM
02/25/13 10:07 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Potentially pistons.......unless you get a rod that equals the increased deck height and the bores match.
Pushrods.
Intake.
That's about it I think.
Re: R3 block 9.6 Deck vs 9.0 [Re: tubtar] #1393162
02/25/13 10:29 AM
02/25/13 10:29 AM
South Carolina
SCMopar Offline OP
SCMopar  Offline OP
South Carolina
Thanks for the reply.. Are the timing covers / chain the same? Do they make an intake for W8 heads that will work on the tall deck block? If not who would be a good resource to make spacers?
Re: R3 block 9.6 Deck vs 9.0 [Re: SCMopar] #1393163
02/25/13 10:36 AM
02/25/13 10:36 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I have both blocks on the shelf if you need one
Re: R3 block 9.6 Deck vs 9.0 [Re: SCMopar] #1393164
02/25/13 06:19 PM
02/25/13 06:19 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Those tall deck MP timing covers require grinding to clear the heads....
Re: R3 block 9.6 Deck vs 9.0 [Re: tubtar] #1393165
02/25/13 10:08 PM
02/25/13 10:08 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Pushrods.
Intake.
Not if you increase the stroke exactly .300". Then you can use the same rods and pistons. More than likely you will want to lengthen the rod a little also giving up some stroke.
Re: R3 block 9.6 Deck vs 9.0 [Re: SCMopar] #1393166
02/25/13 10:11 PM
02/25/13 10:11 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Timing chain is the same. You must have a modified or short deck timing cover now. A stock one will work with the 9.6 deck block. So that is no big deal.
This is pretty simple everthing is the same except the deck on the block. So intake manifold has to be wider, valley pan has to be wider. Pushrods have to be .600" longer if you run the same lifter and camshaft base circle. The timing cover or belt drive plate will have to be taller. It is really pretty simple.
Leon
Re: R3 block 9.6 Deck vs 9.0 [Re: SCMopar] #1393167
02/25/13 10:29 PM
02/25/13 10:29 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Brett Miller has spacers so u CAN use the shortdeck manifold u have on a talldeck.
Re: R3 block 9.6 Deck vs 9.0 [Re: Leon441] #1393168
02/25/13 10:31 PM
02/25/13 10:31 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
yes what they said
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: R3 block 9.6 Deck vs 9.0 [Re: SCMopar] #1393169
02/25/13 11:02 PM
02/25/13 11:02 PM
NY/PA
P
pfm Offline
pfm  Offline
P
NY/PA
check your pm's
Re: R3 block 9.6 Deck vs 9.0 [Re: pfm] #1393170
02/27/13 04:37 PM
02/27/13 04:37 PM
South Carolina
SCMopar Offline OP
SCMopar  Offline OP
South Carolina
Thank you for the info
Re: R3 block 9.6 Deck vs 9.0 [Re: SCMopar] #1393171
03/02/13 11:39 AM
03/02/13 11:39 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
What size are the main bearings and cam bearings in your 9.00 block? Of course if you don't have a cam or crank yet it would not matter.
Bill
