Re: left or right hand thread
[Re: 05dakota]
#139257
10/20/08 11:02 PM
10/20/08 11:02 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
left
70 will be lefty.
If doing a resto, Do yourself a favour and make them rights. Less broken stuff at the tire store.
I've never seen a show judge pull a wheel cover, and look at the end of a stud. And If you are worried abput that, get a letter punch set, and put L's on your rights, and you have the look you need
[Re: Haibach Boys]
#139258
10/21/08 01:27 AM
10/21/08 01:27 AM
Posts: 1,458 oklahoma
forphorty
oklahoma
my 66 coronet, and my 68 super bee, are both left handed lug nuts on the drivers side. for my coronet i thought i could press the lefties out and put right in, on that car NO, i cracked the center hub and bent the crap out of the drum, so i scavenged another passernger one (right handed) and put it on. and i works good so far.
the studs on those cars are swedged (i think thats the word).if you hit them with a grinder in that area it makes them easier to get out.
[Re: forphorty]
#139259
10/21/08 11:33 AM
10/21/08 11:33 AM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
As far as changing studs, I have found that the rear studs can be knocked out, or pressed no problem. If the front drums are 11 inch ( several/all I have worked with)the studs could easily be knocked/ pressed in and out using normal back up around the stud location. The 10 inch drums all needed the swedge cut out/ ground out to be able to remove the studs without destroying the hub.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
