Re: who has bought the center link bushings from MR2perfor [Re: mr2performance] #1392465
02/24/13 02:01 PM
02/24/13 02:01 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Will these lower the center link a little ?
Re: who has bought the center link bushings from MR2perfor [Re: VernMotor] #1392466
02/24/13 06:28 PM
02/24/13 06:28 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
I don't have the exact dimension in front of me, but they end up in almost exactly the same position height wise. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: who has bought the center link bushings from MR2perfor [Re: mr2performance] #1392467
02/24/13 08:51 PM
02/24/13 08:51 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
$100 for 4 or $25 each Mike
And worth every penny too!
In addition to reaming out the holes I put a "step down" on mine where the shoulder of the bushing goes(so that the shoulder side of the bushing is flush with the steering link) and I also run a hardened flat washer under the nut. I had to shorten the non shoulder side of the bushing the thickness of the the shoulder to locate the steering link where I wanted it be.
Something else, I bought a bag of cotter pins the correct size so I never have to reuse them.
Brian
Re: who has bought the center link bushings from MR2perfor [Re: '72CudaRacer] #1392468
02/24/13 09:11 PM
02/24/13 09:11 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
That is a good idea on the step-down on the center link. I shortened the castle nuts on my lathe so the cotter pin will fit through the hole.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: who has bought the center link bushings from MR2perfor [Re: mr2performance] #1392469
02/24/13 09:17 PM
02/24/13 09:17 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I was hoping it would it would lower a little
Re: who has bought the center link bushings from MR2perfor [Re: VernMotor] #1392470
02/24/13 10:56 PM
02/24/13 10:56 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Thanks for the pic. Beep
