Re: who has bought the center link bushings from MR2perfor
[Re: MPerry]
#1392447
02/23/13 05:42 PM
02/23/13 05:42 PM
Posts: 1,169 MI
68shifter
MI
Mikes center links are cheaper than marriage, heck even the champagne room I have two sets. You can ream them yourself or he can. Check these out too. I'm going to grab a set at the Indy show, hopefully. http://monstermopar.com/forum/index.php?topic=1056.0
[Re: MPerry]
#1392455
02/23/13 07:07 PM
02/23/13 07:07 PM
Posts: 29 Maryland
welkerm
Maryland
Call Mike and discuss it with him. We had him do some stuff on our car and it was awesome. We moved everything as necessary/directed and tacked it in place to fit our oil pan hole then mailed it to him, he worked his magic and sent it back. Fits like a glove, turn to turn steering, and very easy to remove to take of the pan and change/check bearings.
Matt Welker
SS/AH 114
A/S 1741
[Re: ]
#1392460
02/24/13 02:49 AM
02/24/13 02:49 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Once you install these on your car, DO NOT tighten the nut like you used to. Just snug the nut up and put the cotter pin in.
Is it because the bushings jamb up on the pitman,idler,and tie rod ends? And you can't get the bushing off?
Hey SSR
[Re: Stanton]
#1392464
02/24/13 01:39 PM
02/24/13 01:39 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
$100 for 4 or $25 each Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: VernMotor]
#1392466
02/24/13 06:28 PM
02/24/13 06:28 PM
mr2performance
Lebanon,IN
I don't have the exact dimension in front of me, but they end up in almost exactly the same position height wise. Mike
765 483 9371
[Re: '72CudaRacer]
#1392468
02/24/13 09:11 PM
02/24/13 09:11 PM
Posts: 1,443 Maryland
Dads426
Maryland
That is a good idea on the step-down on the center link. I shortened the castle nuts on my lathe so the cotter pin will fit through the hole.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: mr2performance]
#1392469
02/24/13 09:17 PM
02/24/13 09:17 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
I was hoping it would it would lower a little
