413 in 1962 Dart #139203
10/20/08 05:03 PM
10/20/08 05:03 PM
Ontario,Canada
robincardodge Offline OP
Ontario,Canada
My steering link is rubbing on my oil pan in my 1962. Anyone know a good fix. Could I file the top off the steering link flat?
Re: 413 in 1962 Dart [Re: robincardodge] #139204
10/20/08 05:10 PM
10/20/08 05:10 PM
You might post a pic of the area you would want to file but it might be better to ding/scallop the pan & deal with it that way
Re: 413 in 1962 Dart [Re: robincardodge] #139205
10/20/08 05:12 PM
10/20/08 05:12 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
There's an oil pan that takes care of this problem. From the C body I believe.
http://www.engine-swaps.com/Car_Craft_December_2000/
Greg
Re: 413 in 1962 Dart [Re: Greg55_99] #139206
10/20/08 05:42 PM
10/20/08 05:42 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
62 dart is a b body not a body
Re: 413 in 1962 Dart [Re: gtx69] #139207
10/20/08 06:29 PM
10/20/08 06:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is it a stock set up? If it is check your motor mounts. The One in my sig is a stock 413 and i had no poroblem with pan clearence.
Re: 413 in 1962 Dart [Re: robincardodge] #139208
10/20/08 07:43 PM
10/20/08 07:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of a '62 Dart with a Max Wedge pan that is longer than a normal BB pan.
Check to be sure somebody hasn't installed the drag link backwards.
Re: 413 in 1962 Dart [Re: John_Kunkel] #139209
10/20/08 08:18 PM
10/20/08 08:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
My 62 Savoy wagon,also Max Wedge pan.At least 1 1/2"" to drain plug and almost 2" below pan.I think the answer in the above post may be your problem.
Re: 413 in 1962 Dart [Re: 62maxwgn] #139210
10/20/08 08:20 PM
10/20/08 08:20 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Another
Re: 413 in 1962 Dart [Re: robincardodge] #139211
10/21/08 10:37 AM
10/21/08 10:37 AM
Ontario,Canada
Ontario,Canada
Thanks guys I found out that you can not use a chrysler pan in a dodge.
