440 build ? #1390704
02/20/13 02:44 AM
02/20/13 02:44 AM
backfire78 Offline OP
building a 440 would like to go 13.5.1 with a 84cc head what pistons
Re: 440 build ? [Re: backfire78] #1390705
02/20/13 04:16 AM
02/20/13 04:16 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
13.5 is quite high. Not a normal street build. Need more info on what you're trying to build here. Also, open chambered heads or closed?
Re: 440 build ? [Re: backfire78] #1390706
02/20/13 04:29 AM
02/20/13 04:29 AM
Custom with a dome, you will need to know in advance to ordering them the desired deck hieght, rod length and wrist pin size needed, bore and stroke(longer strokes are easier to make big compression ) and head gasket thickness you want to use
Re: 440 build ? [Re: DaytonaTurbo] #1390707
02/20/13 04:31 AM
02/20/13 04:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You'll need about a 20CC dome... Easier to run a smaller chamber volume.. Then consider the volume of valve clearance notches..
Re: 440 build ? [Re: 1_WILD_RT] #1390708
02/20/13 04:41 PM
02/20/13 04:41 PM
dogdays Offline
dogdays  Offline
To get to 13.5:1 on a 440 you can have no more than 72cc above the piston. This question belongs in the Race section.
R.
Re: 440 build ? [Re: backfire78] #1390709
02/20/13 04:47 PM
02/20/13 04:47 PM
maryland
74yellowduster Offline
maryland
stroker.
kit.
done.
http://www.440source.com/strokerkits.htm
they have the comp ratios listed
