1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? #1390326
02/19/13 12:02 PM
02/19/13 12:02 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Hello, I have a 1998 Dodge Dakota 4cy. 5 speed 2WD pick up that I use for a shop truck for gas mileage. I am working on getting the truck painted and I Hate the rims that are on it. I would like to put a set of 15" Magnum 500 wheels or a set of aluminium slots on it. Does anyone know of like different front hubs/rotors and rear axle assembly that has 5 lug 4 1/2" Bolt circle that I can put on it? Maybe a different year Dakota? or?
Thanks..in advance..
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: GLR] #1390327
02/19/13 07:38 PM
02/19/13 07:38 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think the early Dakotas were 5-lug. Post in the truck forum and those guys will hook you up.
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: bobby66] #1390328
02/19/13 07:49 PM
02/19/13 07:49 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
The early models were definitely 5 on 4-1/2 BS ... I had cop car wheels on mine !!
You could probably easily find and swap in an early rear end or even an 8-1/4 or 8-3/4 but the front rotors will be the issue ... I don't know if the early and later ones are interchangeable.
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: GLR] #1390329
02/19/13 09:22 PM
02/19/13 09:22 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
it would have to be first gen only, 2nd gen were 6 as well as the 97 and up.. but as far as i know you cant change over to 5 lug unless u find a wheel hub assembly to do it..
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: Dakota_Don] #1390330
02/19/13 10:06 PM
02/19/13 10:06 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Yea...I did some checking and that is the problem. The front hub assembly. I don't know if I can have it re-drilled for the 5 lug pattern or not. I guess I will have to do some more research. I know that Minivans have a slimier front bearing/ Hub assembly and they are 4 1/2 " bolt circle.
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: Dakota_Don] #1390331
02/19/13 10:07 PM
02/19/13 10:07 PM
dogdays Offline
dogdays  Offline
Post on the truck forum, the 5 and 6 lug experts are over there.
R.
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: dogdays] #1390332
02/19/13 10:17 PM
02/19/13 10:17 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Dogdays.... which Truck Forum are you talking about? The Dakotaforums.com ?
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: GLR] #1390333
02/19/13 11:24 PM
02/19/13 11:24 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
worst comes to worst maybe you can call a hub mfg and have them drilled for the 5 lug, the rotors should be easy enuf
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: Dakota_Don] #1390334
02/19/13 11:34 PM
02/19/13 11:34 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I think I would have better luck having the hubs re-drilled at a more local machine shop. Manufacturing places usually won't do custom work, for multiple reasons.
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: GLR] #1390335
02/20/13 12:14 AM
02/20/13 12:14 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
I read 2nd gen can be swapped over to 5 lug. 3rd gen needs to be redrilled. Moser will do it, $90 per hub. How bad do you want it? What's nice is the front hub unbolts from the spindle. I swapped one out when the wheel bearing went bad. Real easy to R&R.
http://www.moserengineering.com/moser/shop-services/
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: sixpack4spd] #1390336
02/20/13 12:18 AM
02/20/13 12:18 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
the 2nd can be swaped real easy by using the 1st gen rotors,.. if you can get the hubs drilled that would be great.. might wanna have them do an extra in case one goes bad..
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: sixpack4spd] #1390337
02/20/13 12:21 AM
02/20/13 12:21 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
We swapped a 96 dakota a few years ago. We used the early 5 lug dakota rotors for the front and swapped out the 8 1/4 for a 9in. That gave the truck a 5x4.5 front and back.
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: Dakota_Don] #1390338
02/20/13 12:24 AM
02/20/13 12:24 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I want to be clear about something... is the 1st Generation 1987-to 1990? and 2nd Generation 1991-96 and third 1997-04...Correct?
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: rallye73] #1390339
02/20/13 12:24 AM
02/20/13 12:24 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
not to high jack, but what were the measurements of the new rear you installed? what did it come from? what mods if any did u have to do?
Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ?? [Re: GLR] #1390340
02/20/13 12:42 AM
02/20/13 12:42 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
Yup, and here's the best Dakota forum:
www.dakota-durango.com
