Re: 1998 Dakota -convert from 6 lug rims to 5 lug 4 1/2" ??
[Re: GLR]
#1390333
02/19/13 11:24 PM
02/19/13 11:24 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
Yea...I did some checking and that is the problem. The front hub assembly. I don't know if I can have it re-drilled for the 5 lug pattern or not. I guess I will have to do some more research. I know that Minivans have a slimier front bearing/ Hub assembly and they are 4 1/2 " bolt circle.
worst comes to worst maybe you can call a hub mfg and have them drilled for the 5 lug, the rotors should be easy enuf
[Re: GLR]
#1390340
02/20/13 12:42 AM
02/20/13 12:42 AM
Posts: 2,874 Upstate, NY
sixpack4spd
Upstate, NY
I want to be clear about something... is the 1st Generation 1987-to 1990? and 2nd Generation 1991-96 and third 1997-04...Correct?
Yup, and here's the best Dakota forum:
www.dakota-durango.com
