What purpose is Big Heavy weight on tailhousing? #13893
01/02/05 01:49 PM
01/02/05 01:49 PM
Fitchburg,Massachusetts
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
There is a heavy damper/weight on the back of my 74 Satellite's 904.
What exactly is the purpose of this thing? I just never noticed them on many cars. ~Mike~
Re: What purpose is Big Heavy weight on tailhousing? [Re: MPerry] #13894
01/02/05 02:04 PM
01/02/05 02:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I'm pretty sure it's there to dampen vibrations and thus noise.
Re: What purpose is Big Heavy weight on tailhousin [Re: autoxcuda] #13895
01/02/05 02:16 PM
01/02/05 02:16 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
Ok I guess a better question would be...Will it hurt anything if I leave it off? I'm not one to complain of slight noises and thing the general public typically would. ~Mike~
Re: What purpose is Big Heavy weight on tailhousin [Re: MPerry] #13896
01/02/05 02:30 PM
01/02/05 02:30 PM
Richmond, VA
VT_Dart Offline
VT_Dart  Offline
Richmond, VA
Just dampens vibration. I've only left it on one car I had and, while it did make a difference, it wasn't that noticeable.
Darrah
Darrah Heath
Re: What purpose is Big Heavy weight on tailhousin [Re: VT_Dart] #13897
01/02/05 02:51 PM
01/02/05 02:51 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
On my '73's, there's also one bolted to the floorpan back by where the pinion snubber would hit.
I did an A- B comparison (with, without) on one of my cars with the weight on the trans, didn't notice any significant difference.
John
Re: What purpose is Big Heavy weight on tailhousin [Re: SattyNoCar] #13898
01/02/05 02:56 PM
01/02/05 02:56 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Darn.. and here I thought it was to reduce wheel stands
Seriously, as mentioned above... its to dampen harmonic vibrations in the drive train and reduce driver discomfort.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: What purpose is Big Heavy weight on tailhousin [Re: MRMOPAR] #13899
01/02/05 03:01 PM
01/02/05 03:01 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
its for easy weight reduction, it also gives you something to throw over the neighbors fence.
my charger also had the one near the pinion snubber area, and on the tailshaft.
Re: What purpose is Big Heavy weight on tailhousin [Re: 5537SG] #13900
01/02/05 03:11 PM
01/02/05 03:11 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
Helps offset fat head syndrom in rally events.
Re: What purpose is Big Heavy weight on tailhousin [Re: dezduster] #13901
01/02/05 05:24 PM
01/02/05 05:24 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Remove it.
Re: What purpose is Big Heavy weight on tailhousin [Re: MPerry] #13902
01/02/05 06:10 PM
01/02/05 06:10 PM
NC
440Jim Offline
440Jim  Offline
NC
If your building a car to cruise on the highway, leave it on. If not, put it on ebay!
Re: What purpose is Big Heavy weight on tailhousin [Re: 440Jim] #13903
01/02/05 06:22 PM
01/02/05 06:22 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
Well its a street/strip car and I have to drive on the highway to get to NewEngland Dragway,E-Town,or where ever else the car takes me.
I have no problem removing it if all it will do is decrease smoothness/quietness. I don't want to remove it if it will cause broken tailhousings or other bad things. ~Mike~
Re: What purpose is Big Heavy weight on tailhousin [Re: MPerry] #13904
01/02/05 06:30 PM
01/02/05 06:30 PM
SattyNoCar Offline
SattyNoCar  Offline
I SERIOUSLY doubt simply removing that weight will cause things to break. My engine shakes worse than a dog in heat at certain RPM's (engine issues) and nothing has spit out in over 7 yrs of driving it this way. (engine otherwise runs fine, just don't have the $$$ to rebuild it and get it properly balanced ).
John
Re: What purpose is Big Heavy weight on tailhousin [Re: SattyNoCar] #13905
01/02/05 06:40 PM
01/02/05 06:40 PM
Löffingen, Germany
The_Mean_Machine Offline
Löffingen, Germany
30.000mi without it - no problem at all
Re: What purpose is Big Heavy weight on tailhousin [Re: The_Mean_Machine] #13906
01/02/05 07:01 PM
01/02/05 07:01 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
Cool!
Now wiw on ebay? j/k ~Mike~
Re: What purpose is Big Heavy weight on tailhousin [Re: MPerry] #13907
01/02/05 07:24 PM
01/02/05 07:24 PM
i got tired of taking those things off of trans tailshafts... so if there is one there, it stays. if not, it stays. i bet i have hauled 100 of them to the scrap yard...
Re: What purpose is Big Heavy weight on tailhousing? [Re: MPerry] #13908
01/02/05 07:38 PM
01/02/05 07:38 PM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
I worked at Chrysler Engineering at the time these dampers were added to the cars. There was even dampers inside the steering wheel on some cars, as well as under the dash. The damper on the trans is a Power plant bending damper (PPD). The car will as a rule get a little noiser as not all cars needed them. Some cars just didn't have the problem, but most did. The heavy damper on the floor pan is called a Boom Damper. Of course it stops the floor pan from booming. Take them off if the noise doesn't bother you.
Re: What purpose is Big Heavy weight on tailhousing? [Re: Cuda67] #13909
01/02/05 08:14 PM
01/02/05 08:14 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
excellent info!!
I think my solid cam and open headers pretty much mask the "boom" factor, but on a street car Id still gas them!
Re: What purpose is Big Heavy weight on tailhousing? [Re: Cuda67] #13910
01/02/05 08:31 PM
01/02/05 08:31 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've notice about this same time (mid 70's) that the Dart SE and Valiant Broughms got a lot of noise reduction stuff.
From your factory experiences what areas needed the most attention for noise reduction ???
I like to make my mopars handle well at the usually adds to ride stiffness and adds to noise, vibration, and harshness (NVH). There are a lot of threads here about adding sound deadner and even frame connectors to reduce NVH
I knew a guy who lived in central Iowa that work for Chrysler in the NVH department.
Re: What purpose is Big Heavy weight on tailhousing? [Re: Cuda67] #13911
01/02/05 09:28 PM
01/02/05 09:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Interesting Comment, any other tidbits you'd like to share? How excatly did the "power plant bending" whatever gets its name? Was anything really "bending"?
Re: What purpose is Big Heavy weight on tailhousing? [Re: jcc] #13912
01/03/05 12:22 AM
01/03/05 12:22 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
You should see the huge round weight that is hanging off the front end of the 8 1/4 rearend in my Jeep liberty. The thing has got to weight twenty pounds with the bracket. The 8 1/4 has lived forever without the damper in older applications. I guess the people today never heard of good vibrations. They still complain about vibrations in the jeep.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
