Re: What purpose is Big Heavy weight on tailhousin
[Re: MPerry]
#13896
01/02/05 02:30 PM
01/02/05 02:30 PM
Posts: 2,936 Richmond, VA
VT_Dart
Richmond, VA
Just dampens vibration. I've only left it on one car I had and, while it did make a difference, it wasn't that noticeable.
Darrah
Darrah Heath
[Re: VT_Dart]
#13897
01/02/05 02:51 PM
01/02/05 02:51 PM
Posts: 16,820 Between Houston & Galveston TX
SattyNoCar
On my '73's, there's also one bolted to the floorpan back by where the pinion snubber would hit.
I did an A- B comparison (with, without) on one of my cars with the weight on the trans, didn't notice any significant difference.
John
[Re: SattyNoCar]
#13898
01/02/05 02:56 PM
01/02/05 02:56 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
Darn.. and here I thought it was to reduce wheel stands
Seriously, as mentioned above... its to dampen harmonic vibrations in the drive train and reduce driver discomfort.
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: 440Jim]
#13903
01/02/05 06:22 PM
01/02/05 06:22 PM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
If your building a car to cruise on the highway, leave it on. If not, put it on ebay!
Well its a street/strip car and I have to drive on the highway to get to NewEngland Dragway,E-Town,or where ever else the car takes me. I have no problem removing it if all it will do is decrease smoothness/quietness. I don't want to remove it if it will cause broken tailhousings or other bad things. ~Mike~
[Re: MPerry]
#13904
01/02/05 06:30 PM
01/02/05 06:30 PM
SattyNoCar
I SERIOUSLY doubt simply removing that weight will cause things to break. My engine shakes worse than a dog in heat at certain RPM's (engine issues) and nothing has spit out in over 7 yrs of driving it this way. (engine otherwise runs fine, just don't have the $$$ to rebuild it and get it properly balanced ).
John
[Re: MPerry]
#13907
01/02/05 07:24 PM
01/02/05 07:24 PM
i got tired of taking those things off of trans tailshafts... so if there is one there, it stays. if not, it stays. i bet i have hauled 100 of them to the scrap yard...
Re: What purpose is Big Heavy weight on tailhousing?
[Re: Cuda67]
#13910
01/02/05 08:31 PM
01/02/05 08:31 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I've notice about this same time (mid 70's) that the Dart SE and Valiant Broughms got a lot of noise reduction stuff. From your factory experiences what areas needed the most attention for noise reduction ??? I like to make my mopars handle well at the usually adds to ride stiffness and adds to noise, vibration, and harshness (NVH). There are a lot of threads here about adding sound deadner and even frame connectors to reduce NVH I knew a guy who lived in central Iowa that work for Chrysler in the NVH department. Quote:
I worked at Chrysler Engineering at the time these dampers were added to the cars. There was even dampers inside the steering wheel on some cars, as well as under the dash. The damper on the trans is a Power plant bending damper (PPD). The car will as a rule get a little noiser as not all cars needed them. Some cars just didn't have the problem, but most did. The heavy damper on the floor pan is called a Boom Damper. Of course it stops the floor pan from booming. Take them off if the noise doesn't bother you.
