451 build #1389968
02/18/13 09:46 PM
02/18/13 09:46 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
gonna build a 451,here's what i got,ported heads,they flow [Email]260@.550[/Email] lift.2.18,1.81 valves,m1 intake,800 holley,1 3/4 headers,and i'm gonna use a mopar .528 cam,also the heads have been milled they are 80 cc's chamber and the pistons are at 0 deck height,any ideas what this thing make horspower wise?this is my first stroker build so i'm winging it.thanks,it's going in a 3/4 ton truck for the time being.
Re: what do u guys think [Re: bigblock4x4] #1389969
02/19/13 12:27 AM
02/19/13 12:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Well my old 446 was a .030 over 440 with 906 heads and the MP .557 cam. It use a Holley Street Dominator intake and a 850 DP and was 10.0 comp. Ran fine on pump gas as I used the KB quench pad pistons to get quench. It also used 1-3/4 headers. I never dynoed it but it ran a best of 11.49 @ 116 in my 3700 lb 63. I would guess it was about 500 flywheel hp. Ron
Re: what do u guys think [Re: 383man] #1389970
02/21/13 01:01 AM
02/21/13 01:01 AM
pana illinois
pana illinois
started clearancing the crank tonight
Re: what do u guys think [Re: bigblock4x4] #1389971
02/21/13 02:32 AM
02/21/13 02:32 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
with the mp528 cam and those heads, I would say right around 500hp.
Re: what do u guys think [Re: bigblock4x4] #1389972
02/21/13 03:43 AM
02/21/13 03:43 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
U using a forged or cast crank? I built my 451 w a cast and clearancing needed was minimal, just a little grinding on the block. I didnt have the crank cut down and it was minimal work to balance with 440source Hbeams and Ross pistons.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 451 build [Re: bigblock4x4] #1389973
02/21/13 01:17 PM
02/21/13 01:17 PM
AndyF Online content
AndyF  Online Content
No reason to wing it, I wrote an entire book on building stroker big block Mopar engines. $20 at Amazon or Mancini Racing.
Re: 451 build [Re: AndyF] #1389974
02/21/13 09:38 PM
02/21/13 09:38 PM
pana illinois
pana illinois
i am using a steel crank,and i am using the shorter 400 rod so i had to do some clearancing on the crank with the piston that i am using.
Re: 451 build [Re: bigblock4x4] #1389975
02/21/13 10:07 PM
02/21/13 10:07 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I just did a 400 block with KB quench dome pistons,Eddie heads and a
Racer Brown SSH-44. Haven't put it in yet but I know of a few others
with this combination and it works good.
Re: 451 build [Re: bigblock4x4] #1389976
02/21/13 10:32 PM
02/21/13 10:32 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
So, how many inches of vacume did you flow those heads at?
Re: 451 build [Re: dart4forte] #1389977
02/22/13 03:05 PM
02/22/13 03:05 PM
pana illinois
pana illinois
i wasn't at the shop when it was done,he is a very smart individual up north,i trust him.that's all i need too know,i would assume 28 though
Re: 451 build [Re: bigblock4x4] #1389978
02/22/13 07:48 PM
02/22/13 07:48 PM
dogdays Offline
dogdays  Offline
Generally speaking, if anyone is quoting head flow it's at 28", as anything less would look low.
260 peak flow from a set of stock ported B heads is a pretty nice job, but not max porting. Of course, when one compares that with the 250cfm STOCK peak flow from a 5.7Hemi head, it starts to look a little weak.
R.
Re: 451 build [Re: dogdays] #1389979
02/22/13 07:53 PM
02/22/13 07:53 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
True. But if you're starting with a big block wedge powered truck it's probably less time & money to build a budget built, low reciprocating mass, 451 than a 3rd Gen Hemi. Or even if it's a smallblock now, the brackets, trans, etc are still cheaper.
Not trying to start sumthin', just sayin,!
Re: 451 build [Re: Dean_Kuzluzski] #1389980
02/23/13 01:00 PM
02/23/13 01:00 PM
pana illinois
pana illinois
truck already has a 440 in it,just wanting too try building a 451,i think it would/should be more FUN,the 440 is healthy,but i think the 451 should b more healthy.money is a restraint,so taking baby steps,little at a time,just upgrading a little.i have been accumulating parts for this build for a couple years,got the pistons rods and crank and block and heads,hopefully i'll find some more parts at the indy swap meet in march,oh yeah!
Re: what do u guys think [Re: 383man] #1389981
02/23/13 01:05 PM
02/23/13 01:05 PM
pana illinois
pana illinois
i'd like too find a used set of those pistons
Re: 451 build [Re: AndyF] #1389982
02/25/13 01:55 AM
02/25/13 01:55 AM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
hey 451boy
whats your book called? I have built a few of these and might be building another but want to do it a little different from the last few,always looking for ideas.
who is that guy?
Re: 451 build [Re: bigblock4x4] #1389983
02/25/13 11:30 AM
02/25/13 11:30 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Low deck strokers are a great motor & yours should make some power,
but in a 4x4, low end torque is a must, especially if you have big off road tires. Ask me how I know! I sold the 451 torque monster I built for my Barracuda & installed a 70 383 mag with a little smaller cam than yours (power band was 2500-6500), stock 906's, and with the
35x12.5x16.5 BFG's on my 71 Power Wagon (3.55's), street manners sucked! Low vacuum, lotta gas to get it rollin. Wasn't much fun. I just installed a small Comp cam & new 906's and its a different truck.
If you've got 4:10's or lower & a stick, it might be more street friendly. Just my 2 cents. Your build should make 500 if the heads don't hold it back a little & should have mid 500's torque, too.
Best of luck with your build.
Re: 451 build [Re: Triggerfish] #1389984
02/26/13 08:50 PM
02/26/13 08:50 PM
Iceland
BadMoonRacer Offline
Iceland
Here is that book being mentioned.
http://www.amazon.com/Build-Max-performa...dy+finkelbeiner
I own a copy and have found it very useful. It should belong to any good library devoted to Mopar literature.
Regards
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: 451 build [Re: BadMoonRacer] #1389985
02/27/13 12:51 AM
02/27/13 12:51 AM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Regards
Ragnar in Iceland
it is because of Andy (451boy) that started building low deck strokers,since then did a small block and even a modern Hemi
who is that guy?
Re: 451 build [Re: Triggerfish] #1389986
02/27/13 02:55 PM
02/27/13 02:55 PM
pana illinois
pana illinois
triggerfish i want ur truck,awesome.i am gonna put the 451 in my fourwheel drive,but would love too find about a 65 66 shortbed truck too put it in,and go out and stomp some mustang and camaro tail,thanks for the awesome feedbacks everyone
