Re: UPDATE: bog/hesitation/stumble
[Re: rnch]
#1389856
02/18/13 04:56 PM
02/18/13 04:56 PM
Posts: 15,487 Florida
scratchnfotraction
did you replace the carb or the power piston doohicky? what did you do to fix it in other words? nice to get updates for ?s. did you go 4-v? spill the beans..
[Re: scratchnfotraction]
#1389857
02/18/13 05:26 PM
02/18/13 05:26 PM
Posts: 4,981 new jersey usa
11secdart
new jersey usa
Glad you found the problem, I`ve been having problems with my D 150 for awhile now it would just stop running and when I race it it would start missing at high rpms, I changed plugs, plug wires , cap and rotor, gas filter, I even put the stock computer back in and still had the same problem. Well today I went to take it out of the trailer ( its winter resting spot) to take it to a body shop to get an estimate on some touch up work and it wouldn`t stay running, it would start run awhile then shut off again, then be hard starting. Years ago I put in an Accel coil I decided to put the stock coil back in to see what would happen, Well it started right up and the miss went away, anybody else have a problem with these coils?
