lock tight on connecting rod bolts #1389718
02/18/13 02:31 PM
02/18/13 02:31 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
Would it be a good idea to put lock tight on connecting
rod nuts/bolts.
Re: lock tight on connecting rod bolts [Re: moparmikethree] #1389719
02/18/13 02:39 PM
02/18/13 02:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would say no, and not nec.
Re: lock tight on connecting rod bolts [Re: buildanother] #1389720
02/18/13 02:46 PM
02/18/13 02:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No need.
Re: lock tight on connecting rod bolts [Re: moparmikethree] #1389721
02/18/13 02:52 PM
02/18/13 02:52 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No!!NO!
Re: lock tight on connecting rod bolts [Re: moparmikethree] #1389722
02/18/13 02:55 PM
02/18/13 02:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
rod nuts/bolts.
No, the only thing to put on the threads is oil, FYI there are 2 torque values for a fastner, wet or dry, use the proper one
Mike
Re: lock tight on connecting rod bolts [Re: DAYCLONA] #1389723
02/18/13 07:57 PM
02/18/13 07:57 PM
I use 30wt non synthetic eng oil on rod bolts then blow em off with shop air. After torquing I wouldn't have a problem with adding some green loctite to the threads on the end which the "green" is designed to wick down into threads with them assembled tho with them already coated with a thin film of eng oil the loctite might not bond properly but a person could clean the end threads with a shot of brake kleen or similar first & it'd be worth a try & cheap & I'd sleep better at night . I've only has a con rod bolt come loose once & that was on a DD /6
Re: lock tight on connecting rod bolts [Re: RapidRobert] #1389724
02/19/13 01:34 AM
02/19/13 01:34 AM
Never in a hundred years would I even think of doing that ROBERT why would you want to take a chance of those chemicals getting into the oil after warming the motor up The factory uses oil and has for a lot of years, the nut and bolt are designed to have a set amount of clamping force with the oil set at the torque recommendned, not any other lubricants or chemicals
Re: lock tight on connecting rod bolts [Re: Cab_Burge] #1389725
02/19/13 01:48 AM
02/19/13 01:48 AM
dogdays Offline
dogdays  Offline
R.
Loctite does not belong on them.
Re: lock tight on connecting rod bolts [Re: Cab_Burge] #1389726
02/19/13 01:58 AM
02/19/13 01:58 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
arp makes a very good rod bolt lube. you need to understand that the rod bolt is tightened to yeild a stretch value. this places a clamping load on the bolt. if the bolts are properly installed [not binding at the shank]they should torque to specs.the use of lube greatly effects the actual load applied. a bolt can bind and yeild a false torque spec,then loosen up with use. i would never use lock tite....
Re: lock tight on connecting rod bolts [Re: RapidRobert] #1389727
02/19/13 08:37 AM
02/19/13 08:37 AM
Cincinnati, Ohio
Cincinnati, Ohio
Are you kidding us? I can't believe you even posted this?
Re: lock tight on connecting rod bolts [Re: ek3] #1389728
02/19/13 10:36 AM
02/19/13 10:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
ARP lube requires a different torque spec than using oil , the factory manual torque specs are using oil .
Re: lock tight on connecting rod bolts [Re: Challenger 1] #1389729
02/19/13 10:37 AM
02/19/13 10:37 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I can ...
Re: lock tight on connecting rod bolts [Re: JohnRR] #1389730
02/19/13 12:27 PM
02/19/13 12:27 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
if you are oiling them, or lubing them with ARP lube dont forget to apply some under the head, as that can alter torque readings if that is left dry and the threads are wet.
Re: lock tight on connecting rod bolts [Re: JohnRR] #1389731
02/20/13 01:30 AM
02/20/13 01:30 AM
E
ek3 Offline
ek3  Offline
E
DUH! I SAID A BOLT IS TIGHTENED TO YEILD A STRETCH VALUE- NOT TORQUE. please re-read post. .. yea i know,they dont make good quaker state like the old days,that will throw the old manuals specs off a mile rite there.. while you are at it,if you want to ensure the rod bolts are the best they can be,use arp brand bolts. they will require about 50 lbs torque to yeild proper stretch as compared to the stock 45 lbs... Also, rod bolts stretch with each use-
Re: lock tight on connecting rod bolts [Re: ek3] #1389732
02/20/13 10:46 AM
02/20/13 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Oh boy another narcissistic [censored] with internet access ... wonderful ...
ARP bolt lube is for ARP bolts, ARP is the only maker I know of that gives a spec for bolt stretch. You are ASSuMEing that everyone uses ARP bolts and owns a bolt stretch gauge , I DON'T assume that which is why I was pointing it out to those that are just reading along.
Re: lock tight on connecting rod bolts [Re: JohnRR] #1389733
02/20/13 11:08 AM
02/20/13 11:08 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
ARP bolt lube is for ARP bolts, ARP is the only maker I know of that gives a spec for bolt stretch. You are ASSuMEing that everyone uses ARP bolts and owns a bolt stretch gauge , DON'T ...
I've used those old O.E.M. bolts over and over for 40+years and have yet have the first one come loose !!
Re: lock tight on connecting rod bolts [Re: 62maxwgn] #1389734
02/20/13 04:37 PM
02/20/13 04:37 PM
dogdays Offline
dogdays  Offline
UNLESS a rod bolt is a torque-to-yield type IT DOES NOT GET LONGER with each use.
Torque is generally set at 75% - 80% of yield strength. That is still in the elastic region.
You have to exceed yield strength to permanently elongate the bolt, called plastic deformation.
R.
Re: lock tight on connecting rod bolts [Re: JohnRR] #1389735
02/20/13 11:36 PM
02/20/13 11:36 PM
E
ek3 Offline
ek3  Offline
E
ARP bolt lube is for ARP bolts, ARP is the only maker I know of that gives a spec for bolt stretch. You are ASSuMEing that everyone uses ARP bolts and owns a bolt stretch gauge ---[ your words not mine]-- I DON'T assume that which is why I was pointing it out to those that are just reading along. --[ you assume the OP. was using a stock bolt then. he never said that . what if he had arp bolts and you said use oil? just so those reading along dont use the wrong oil on their arp bolts!] --- [/te] ARP will work on the stock bolts just fine. the torque value will change but not the stretch. all rod bolts stretch. no assumption. the factory issued torque spec. is a value that will usually give the needed stretch to that bolt. just to be clear when i say all rod bolts stretch, while torqued to specs .
Re: lock tight on connecting rod bolts [Re: ek3] #1389736
02/20/13 11:43 PM
02/20/13 11:43 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Re: lock tight on connecting rod bolts [Re: 70runner] #1389737
02/21/13 12:45 AM
02/21/13 12:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
