Re: Need help decoding a 440 block ????
[Re: Dartman928]
#1389305
02/17/13 11:05 PM
02/17/13 11:05 PM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
I have some numbers off a block and was wondering if someone could help decode it.
Along the bottom of the block by the oil pan reads:
OB232872
One the side of the block mid way up has:
25364306
11/13/69
Thanks for your help
0 (zero not the letter "O") = 1970
B = Hamtramck vehicle assembly plant
232872 = the last six digits of the VIN
[Re: Dartman928]
#1389306
02/17/13 11:09 PM
02/17/13 11:09 PM
A12
N.E. OHIO, USA
OB232872
25364306
11/13/69 = block casting date November 13, 1969
[Re: Dartman928]
#1389307
02/17/13 11:10 PM
02/17/13 11:10 PM
A12
N.E. OHIO, USA
OB232872
25364306 oops, = block part number
11/13/69
[Re: Dartman928]
#1389308
02/18/13 11:21 AM
02/18/13 11:21 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
it has 440 HP2 on the pad
What is stamped on that pad , those are the numbers to help identify what it is less than casting numbers and date ...
