Need help decoding a 440 block ???? #1389301
02/17/13 10:16 PM
02/17/13 10:16 PM
IN
Dartman928 Offline OP
IN
I have some numbers off a block and was wondering if someone could help decode it.
Along the bottom of the block by the oil pan reads:
OB232872
One the side of the block mid way up has:
25364306
11/13/69
Thanks for your help
Re: Need help decoding a 440 block ???? [Re: Dartman928] #1389302
02/17/13 10:38 PM
02/17/13 10:38 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It's a 1970 motor. Those numbers are the last 8 of the VIN. You need to get the numbers and letters from the top front engine pad next to the distributor on the driver's side.
Re: Need help decoding a 440 block ???? [Re: RoadRunnerJD] #1389303
02/17/13 10:43 PM
02/17/13 10:43 PM
IN
IN
it has 440 HP2 on the pad
Re: Need help decoding a 440 block ???? [Re: Dartman928] #1389304
02/17/13 10:45 PM
02/17/13 10:45 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It came out of a 1970 Challenger, but the number is a new one to me.
Re: Need help decoding a 440 block ???? [Re: Dartman928] #1389305
02/17/13 11:05 PM
02/17/13 11:05 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
OB232872
25364306
11/13/69
0 (zero not the letter "O") = 1970
B = Hamtramck vehicle assembly plant
232872 = the last six digits of the VIN
Re: Need help decoding a 440 block ???? [Re: Dartman928] #1389306
02/17/13 11:09 PM
02/17/13 11:09 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
OB232872
25364306
11/13/69 = block casting date November 13, 1969
Re: Need help decoding a 440 block ???? [Re: Dartman928] #1389307
02/17/13 11:10 PM
02/17/13 11:10 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
OB232872
25364306 oops, = block part number
11/13/69
Re: Need help decoding a 440 block ???? [Re: Dartman928] #1389308
02/18/13 11:21 AM
02/18/13 11:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is stamped on that pad , those are the numbers to help identify what it is less than casting numbers and date ...
