540 veney headed hemi #1388736
02/16/13 09:37 PM
02/16/13 09:37 PM
SW WI
cudacustoms1 Offline OP
SW WI
Just got home today with my new (well new to me) motor for my 2wd pulling truck.Thought some of you guys might like to see some pics of it. It is a standard deck spread lifter brad billet block.Veney 2.5 heads. Setback manifold.Just freashened at veney's. 4.5 bryant crank. MGP rods. 4.375 bore.
Re: 540 veney headed hemi [Re: cudacustoms1] #1388737
02/16/13 09:44 PM
02/16/13 09:44 PM
SW WI
SW WI
The "old" BAE and the new veney.
Re: 540 veney headed hemi [Re: cudacustoms1] #1388738
02/16/13 09:50 PM
02/16/13 09:50 PM
SW WI
SW WI
Last one
Re: 540 veney headed hemi [Re: cudacustoms1] #1388739
02/16/13 10:03 PM
02/16/13 10:03 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I happened to see it when I was out at Veney's Monday dropping of a gasket order.
Wish I would have known you were getting it, we could have met out there.
Very few people have a shot at getting one of them, good for you I'm sure you'll be pleased with it. Hope you like the valve cover gaskets
Let's see your 2WD
Re: 540 veney headed hemi [Re: roadhazard] #1388740
02/16/13 10:57 PM
02/16/13 10:57 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What a combo! Your playing with power now
Re: 540 veney headed hemi [Re: roadhazard] #1388741
02/17/13 05:16 AM
02/17/13 05:16 AM
SW WI
SW WI
Thanks. Here is a pic of the truck as of last year. I am redoing the body for this year and hopefully will get painted apple kandys. We are very exited to get in the chassie and here it run but it is going to be awhile alot of parts are different from my last deal.
Re: 540 veney headed hemi [Re: cudacustoms1] #1388742
02/17/13 09:28 AM
02/17/13 09:28 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Need someone to haul that old scrap away for you?
Re: 540 veney headed hemi [Re: 67_Satellite] #1388743
02/17/13 12:44 PM
02/17/13 12:44 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Nice.....very nice.
Re: 540 veney headed hemi [Re: cudacustoms1] #1388744
02/17/13 02:19 PM
02/17/13 02:19 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
That thing looks evil
Gus
64 Plymouth Savoy
Dana 60
Re: 540 veney headed hemi [Re: fourgearsavoy] #1388745
02/17/13 03:00 PM
02/17/13 03:00 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Very nice! Did Goodwin work on this one>?
Re: 540 veney headed hemi [Re: Diablo] #1388746
02/17/13 03:12 PM
02/17/13 03:12 PM
SW WI
SW WI
yes he worked on the BAE motor.
Re: 540 veney headed hemi [Re: cudacustoms1] #1388747
02/17/13 03:19 PM
02/17/13 03:19 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Why the switch to a Veney motor? Is it better than a BAE? And what is a pinched chamber Veney head (don't know if yours is but it popped up when I googled Veney HEMI)
Re: 540 veney headed hemi [Re: WO23Coronet] #1388748
02/17/13 08:42 PM
02/17/13 08:42 PM
SW WI
SW WI
It is better in the pulling world. The brad heads need to be run lean to make good power. The veneys tend to be able to be run a little richer and still make good power.In the pulling sport the motors are wide open for 10-15 seconds with the biggest load at the end. With that much load and heat if you don't have a little extra fuel BANG! I learned the hard way. The pinch or bathtub heads are something new. I was told there are only 7 motors out with that style heads at this time. I run against 2 of them. The head is the same as the regular heads but side of the chamber are filled in.There is 2 versions 2.6 and 2.5. Most of the veney heads are called by the intake valve size. As for hauling away the old junk. It needs to find a new home but I don't think I am ready to give it away just yet.
Re: 540 veney headed hemi [Re: cudacustoms1] #1388749
02/17/13 10:42 PM
02/17/13 10:42 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
How much for the brad engine? What block, crank and heads is it?
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 540 veney headed hemi [Re: bigtimeauto] #1388750
02/18/13 10:34 AM
02/18/13 10:34 AM
SW WI
SW WI
It would be best for you to call me and I can give you all the info I have on this motor but here is the high lights. BAE std deck billet spread lifter block. 4.375 bore. BAE stage 4 fatheads. Silver stand high ratio rocker gear.RCD billet gear drive. BME rods. Williams pan. KB ultra oil pump. 4.5 bryant crank.This motor can be bought freash hat to pan ready to run witha kobelco 14-71 HH w/ all the DMPE mods. 11mm pulleys belts ,spares etc or intake down as is and you freashen and change what you want. $22,000 for freash long block Again call me if you are even thinking about it and we can talk more .Way to many details to type. Thanks Chad Haggerty 608 485 0760 eves
Re: 540 veney headed hemi [Re: cudacustoms1] #1388751
02/18/13 11:46 AM
02/18/13 11:46 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
OK
